“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
LemonMeringueTy
Re: “Fatal Error Occured” with MacOS 15.4 Developer Beta 1
#31 Post by LemonMeringueTy » Wed Mar 05, 2025 11:27 pm
lostinlodos wrote: Tue Mar 04, 2025 7:01 pm
ds1972 wrote: Tue Mar 04, 2025 2:10 am Unfortunately, Beta 2 doesn't correct the issue.
Damn. I was just going to suggest everyone hang on a half hour while I updated.
Apple locked down a LOT of things in 15.4. I'm spending almost as much time in privacy and security settings as I am using apps for the moment.
As a few others have said, this is a newly-locked access route that was previously open.
Apple locked down optical device access somewhere that was open before.
same access problem a few other apps, including VM and translation apps.
It's odd that the MakeMKV-alternatives still work. They're just not as good as MakeMKV. Looking at you AnyMP4.
mechanic57
#32 Post by mechanic57 » Sat Mar 08, 2025 12:51 pm
In the notes that came with 15.4.1 release Apple have made significant changes to all their SCSI handling procedures. Did anyone notice that their DVDPlayer App has disappeared and replaced with a "Viewer"?
Like most I now use the MakeMKV on a different Mac which has an Intel processor and it works fine.
ds1972
#33 Post by ds1972 » Mon Mar 10, 2025 11:19 pm
Beta 3 does not correct this. Has anyone heard from the MakeMKV devs if they're looking into the issue?
DocT1973
#34 Post by DocT1973 » Tue Mar 11, 2025 12:06 am
Hey,
I have not heard from Apple nor the developer. Beta updates should come weekly now.
asr101
#35 Post by asr101 » Wed Mar 12, 2025 3:02 pm
Given the comment above about the changes to SCSI protocols, it would seem this is a problem that the MakeMKV developers need to find a solution to. I sort of wish they would chime in here and give us, at least, a "we're looking into it". Fortunately I have an older MBP that runs MakeMKV for now.
NESSNES404
#36 Post by NESSNES404 » Fri Mar 14, 2025 5:23 pm
Still broken on macOS Sequoia 15.4 Beta 3
  System Version:	macOS 15.4 (24E5228e)
  Kernel Version:	Darwin 24.4.0
Translated Report (Full Report Below)
Process:               makemkvcon [1777]
Path:                  /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
Identifier:            makemkvcon
Version:               ???
Code Type:             ARM-64 (Native)
Parent Process:        makemkv [1775]
Responsible:           makemkv [1775]
User ID:               501
Date/Time:             2025-03-14 13:20:52.2124 -0400
OS Version:            macOS 15.4 (24E5228e)
Report Version:        12
Anonymous UUID:        9EDCF247-5629-917E-0DDB-4FCCD45D555B
Time Awake Since Boot: 170 seconds
System Integrity Protection: enabled
Crashed Thread:        5
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Codes:       0x0000000000000001, 0x0000000000000008
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [1777]
VM Region Info: 0x8 is not in any region.  Bytes before following region: 4376920056
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      104e28000-1052b4000    [ 4656K] r-x/r-x SM=COW  /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
Thread 0::  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	       0x18054d9b8 __ulock_wait + 8
1   libsystem_pthread.dylib       	       0x1805900a8 _pthread_join + 608
2   makemkvcon                    	       0x10511e950 0x104e28000 + 3107152
3   makemkvcon                    	       0x104e2b558 0x104e28000 + 13656
4   dyld                          	       0x1801eeb4c start + 6000
Thread 1:
0   libsystem_kernel.dylib        	       0x18054bbb0 semaphore_wait_trap + 8
1   makemkvcon                    	       0x104fdd544 0x104e28000 + 1791300
2   makemkvcon                    	       0x104fe0830 0x104e28000 + 1804336
3   libsystem_pthread.dylib       	       0x18058dc0c _pthread_start + 136
4   libsystem_pthread.dylib       	       0x180588b80 thread_start + 8
Thread 2:
0   libsystem_pthread.dylib       	       0x180588b6c start_wqthread + 0
Thread 3:
Thread 4:
Thread 5 Crashed:
0   makemkvcon                    	       0x10511b718 0x104e28000 + 3094296
1   makemkvcon                    	       0x104f87a54 0x104e28000 + 1440340
2   makemkvcon                    	       0x104e337c0 0x104e28000 + 47040
3   makemkvcon                    	       0x104e33538 0x104e28000 + 46392
4   makemkvcon                    	       0x104e333c8 0x104e28000 + 46024
5   makemkvcon                    	       0x10511d4e0 0x104e28000 + 3101920
6   makemkvcon                    	       0x105117e14 0x104e28000 + 3079700
7   makemkvcon                    	       0x105104318 0x104e28000 + 2999064
8   makemkvcon                    	       0x1051085dc 0x104e28000 + 3016156
9   makemkvcon                    	       0x10511fa7c 0x104e28000 + 3111548
10  makemkvcon                    	       0x10511ed54 0x104e28000 + 3108180
11  makemkvcon                    	       0x10511ebb0 0x104e28000 + 3107760
12  libsystem_pthread.dylib       	       0x18058dc0c _pthread_start + 136
13  libsystem_pthread.dylib       	       0x180588b80 thread_start + 8
Thread 6:
0   libsystem_kernel.dylib        	       0x18054c7dc read + 8
1   makemkvcon                    	       0x105120a18 0x104e28000 + 3115544
2   makemkvcon                    	       0x10511f360 0x104e28000 + 3109728
Thread 5 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000000   x1: 0x0000000000000000   x2: 0x00000000e4c15c00   x3: 0x00000000e4c15c09
    x4: 0x00000000e4c15c12   x5: 0x00000000986773b1   x6: 0x00000000e1032cee   x7: 0x00000000986717dd
    x8: 0x0000000000000008   x9: 0x0000000000000000  x10: 0x340ce5283c95007b  x11: 0x0000000000000008
   x12: 0x0000000000000000  x13: 0x000000000000000e  x14: 0x0000000000000000  x15: 0x0000000180594810
   x16: 0x0000000000000b40  x17: 0x0000000000000001  x18: 0x0000000000000000  x19: 0x0000000105554000
   x20: 0x0000000000000000  x21: 0x000000005f85dff7  x22: 0x00000000a1682538  x23: 0x00000001051ec990
   x24: 0x0000000000000045  x25: 0x0000000074940ce4  x26: 0x0000000000000001  x27: 0x00000000000493df
   x28: 0x00000001051ec5d0   fp: 0x000000016b28e990   lr: 0x000000010511b6ec
    sp: 0x000000016b28e960   pc: 0x000000010511b718 cpsr: 0x80001000
   far: 0x0000000000000008  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x104e28000 -        0x1052b3fff makemkvcon (*) <00000000-0000-0000-0000-000000000000> /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
       0x1053f4000 -        0x105413fff libmakemkv.dylib (*) <00000000-0000-0000-0000-000000000000> /Applications/MakeMKV.app/Contents/MacOS/libmakemkv.dylib
       0x10538c000 -        0x10538ffff libdriveio.dylib (*) <00000000-0000-0000-0000-000000000000> /Applications/MakeMKV.app/Contents/MacOS/libdriveio.dylib
       0x105c80000 -        0x105e37fff libffm.dylib (*) <00000000-0000-0000-0000-000000000000> /Applications/MakeMKV.app/Contents/MacOS/libffm.dylib
       0x18054b000 -        0x18058631b libsystem_kernel.dylib (*) <7999ac2c-4b9b-3494-83b3-45de3163cf9a> /usr/lib/system/libsystem_kernel.dylib
       0x180587000 -        0x180593a47 libsystem_pthread.dylib (*) <d006fbde-80f8-3460-b710-6587e6df2d5c> /usr/lib/system/libsystem_pthread.dylib
       0x1801e8000 -        0x180282a7b dyld (*) <21de849b-1568-3075-b33a-c85e2023e0fe> /usr/lib/dyld
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x180594000 -        0x1805c3b03 libdyld.dylib (*) <33a7942a-7085-31b4-be35-00f98b6d4ff6> /usr/lib/system/libdyld.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=851.9M resident=0K(0%) swapped_out_or_unallocated=851.9M(100%)
Writable regions: Total=1.2G written=402K(0%) resident=402K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
Kernel Alloc Once                   32K        1
MALLOC                             1.2G       26
MALLOC guard page                   96K        6
STACK GUARD                       56.1M        7
Stack                             11.2M        7
VM_ALLOCATE                        912K        1
__AUTH                             822K      161
__AUTH_CONST                      12.8M      295
__DATA                            20.1M      281
__DATA_CONST                      11.4M      299
__DATA_DIRTY                       452K       88
__FONT_DATA                        2352        1
__LINKEDIT                       620.4M        5
__OBJC_RO                         61.3M        1
__OBJC_RW                         2391K        1
__TEXT                           231.5M      308
__TPRO_CONST                       128K        2
mapped file                       32.5M        2
page table in kernel               402K        1
shared memory                      192K        6
TOTAL                              2.2G     1500
Full Report
{"app_name":"makemkvcon","timestamp":"2025-03-14 13:20:55.00 -0400","app_version":"","slice_uuid":"00000000-0000-0000-0000-000000000000","build_version":"","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 15.4 (24E5228e)","roots_installed":0,"incident_id":"1E2F6D4D-C697-4B90-90B0-E54B3C1F5893","name":"makemkvcon"}
  "uptime" : 170,
  "procRole" : "Unspecified",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "Mac14,15",
  "coalitionID" : 1395,
  "osVersion" : {
    "train" : "macOS 15.4",
    "build" : "24E5228e",
    "releaseType" : "User"
  "captureTime" : "2025-03-14 13:20:52.2124 -0400",
  "codeSigningMonitor" : 1,
  "incident" : "1E2F6D4D-C697-4B90-90B0-E54B3C1F5893",
  "pid" : 1777,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2025-03-14 13:20:51.6647 -0400",
  "procStartAbsTime" : 4267640811,
  "procExitAbsTime" : 4280772197,
  "procName" : "makemkvcon",
  "procPath" : "\/Applications\/MakeMKV.app\/Contents\/MacOS\/makemkvcon",
  "parentProc" : "makemkv",
  "parentPid" : 1775,
  "coalitionName" : "com.makemkv.MakeMKV",
  "crashReporterKey" : "9EDCF247-5629-917E-0DDB-4FCCD45D555B",
  "appleIntelligenceStatus" : {"state":"available"},
  "responsiblePid" : 1775,
  "responsibleProc" : "makemkv",
  "codeSigningID" : "makemkvcon-a345d3af707c4029c063fe0620c1b6a672dd01cf",
  "codeSigningTeamID" : "",
  "codeSigningFlags" : 570425857,
  "codeSigningValidationCategory" : 10,
  "codeSigningTrustLevel" : 4294967295,
  "codeSigningAuxiliaryInfo" : 0,
  "instructionByteStream" : {"beforePC":"CPR+kj8FAHGgAABUFACA0gkBADUIIQCRBAAAFAgBQPkIAUD5CIEAkQ==","atPC":"CAFA+RTNdJL\/CwC59gsAuXQKALQopIRSCC20cimnhFIJLbRyAwAAFA=="},
  "bootSessionUUID" : "5954B3DD-EE22-4DDC-955F-B8FF1686CC8A",
  "sip" : "enabled",
  "vmRegionInfo" : "0x8 is not in any region.  Bytes before following region: 4376920056\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      104e28000-1052b4000    [ 4656K] r-x\/r-x SM=COW  \/Applications\/MakeMKV.app\/Contents\/MacOS\/makemkvcon",
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000008","rawCodes":[1,8],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000008"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1777},
  "vmregioninfo" : "0x8 is not in any region.  Bytes before following region: 4376920056\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      104e28000-1052b4000    [ 4656K] r-x\/r-x SM=COW  \/Applications\/MakeMKV.app\/Contents\/MacOS\/makemkvcon",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 5,
  "threads" : [{"id":18793,"threadState":{"x":[{"value":18446744073709551612},{"value":0},{"value":8963},{"value":0},{"value":50593839},{"value":3},{"value":0},{"value":0},{"value":8963},{"value":16908290},{"value":17},{"value":0},{"value":8308535896,"symbolLocation":0,"symbol":"vm_page_size"},{"value":5},{"value":2208804870},{"value":2206705675},{"value":515},{"value":8325728664},{"value":0},{"value":6092812288},{"value":2},{"value":6092812340},{"value":16908290},{"value":8308493472,"symbolLocation":224,"symbol":"_main_thread"},{"value":8308539460,"symbolLocation":0,"symbol":"_pthread_list_lock"},{"value":17},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6448283816},"cpsr":{"value":1073745920},"fp":{"value":6089961520},"sp":{"value":6089961424},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6448011704},"far":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":10680,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":4},{"imageOffset":37032,"symbol":"_pthread_join","symbolLocation":608,"imageIndex":5},{"imageOffset":3107152,"imageIndex":0},{"imageOffset":13656,"imageIndex":0},{"imageOffset":27468,"symbol":"start","symbolLocation":6000,"imageIndex":6}]},{"id":18804,"frames":[{"imageOffset":2992,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":4},{"imageOffset":1791300,"imageIndex":0},{"imageOffset":1804336,"imageIndex":0},{"imageOffset":27660,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":5},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":5}],"threadState":{"x":[{"value":14},{"value":0},{"value":1},{"value":155},{"value":6090518528},{"value":319029279},{"value":0},{"value":0},{"value":18446744073709551614},{"value":1},{"value":4382236640},{"value":1},{"value":0},{"value":2045},{"value":2151940091},{"value":2149840891},{"value":18446744073709551580},{"value":6090518528},{"value":0},{"value":4382236664},{"value":4382236648},{"value":2863311531},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4378711364},"cpsr":{"value":1610616832},"fp":{"value":6090518400},"sp":{"value":6090518384},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6448004016},"far":{"value":0}}},{"id":18805,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"x":[{"value":6091091968},{"value":5635},{"value":6090555392},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6091091968},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6448253804},"far":{"value":0}}},{"id":18806,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"x":[{"value":6091665408},{"value":10499},{"value":6091128832},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6091665408},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6448253804},"far":{"value":0}}},{"id":18807,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"x":[{"value":6092238848},{"value":0},{"value":6091702272},{"value":0},{"value":278532},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6092238848},"esr":{"value":0,"description":" Address size fault"},"pc":{"value":6448253804},"far":{"value":0}}},{"triggered":true,"id":18808,"threadState":{"x":[{"value":0},{"value":0},{"value":3837877248},{"value":3837877257},{"value":3837877266},{"value":2556916657},{"value":3775081710},{"value":2556893149},{"value":8},{"value":0},{"value":3750624550670631035},{"value":8},{"value":0},{"value":14},{"value":0},{"value":6448302096},{"value":2880},{"value":1},{"value":0},{"value":4384440320},{"value":0},{"value":1602609143},{"value":2707957048},{"value":4380871056},{"value":69},{"value":1955859684},{"value":1},{"value":299999},{"value":4380870096}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4380014316},"cpsr":{"value":2147487744},"fp":{"value":6092810640},"sp":{"value":6092810592},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4380014360,"matchesCrashFrame":1},"far":{"value":8}},"frames":[{"imageOffset":3094296,"imageIndex":0},{"imageOffset":1440340,"imageIndex":0},{"imageOffset":47040,"imageIndex":0},{"imageOffset":46392,"imageIndex":0},{"imageOffset":46024,"imageIndex":0},{"imageOffset":3101920,"imageIndex":0},{"imageOffset":3079700,"imageIndex":0},{"imageOffset":2999064,"imageIndex":0},{"imageOffset":3016156,"imageIndex":0},{"imageOffset":3111548,"imageIndex":0},{"imageOffset":3108180,"imageIndex":0},{"imageOffset":3107760,"imageIndex":0},{"imageOffset":27660,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":5},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":5}]},{"id":18810,"frames":[{"imageOffset":6108,"symbol":"read","symbolLocation":8,"imageIndex":4},{"imageOffset":3115544,"imageIndex":0},{"imageOffset":3109728,"imageIndex":0},{"imageOffset":27660,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":5},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":5}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":105553135321168},{"value":6093385728},{"value":319029295},{"value":0},{"value":0},{"value":4380029772},{"value":9732},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":3},{"value":8325728648},{"value":0},{"value":105553135321168},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4380035608},"cpsr":{"value":536875008},"fp":{"value":6093385632},"sp":{"value":6093385616},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6448007132},"far":{"value":0}}}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4376920064,
    "size" : 4767744,
    "uuid" : "00000000-0000-0000-0000-000000000000",
    "path" : "\/Applications\/MakeMKV.app\/Contents\/MacOS\/makemkvcon",
    "name" : "makemkvcon"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4382998528,
    "size" : 131072,
    "path" : "\/Applications\/MakeMKV.app\/Contents\/MacOS\/libmakemkv.dylib",
    "name" : "libmakemkv.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4382572544,
    "size" : 16384,
    "path" : "\/Applications\/MakeMKV.app\/Contents\/MacOS\/libdriveio.dylib",
    "name" : "libdriveio.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4391960576,
    "size" : 1802240,
    "path" : "\/Applications\/MakeMKV.app\/Contents\/MacOS\/libffm.dylib",
    "name" : "libffm.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6448001024,
    "size" : 242460,
    "uuid" : "7999ac2c-4b9b-3494-83b3-45de3163cf9a",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6448246784,
    "size" : 51784,
    "uuid" : "d006fbde-80f8-3460-b710-6587e6df2d5c",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6444449792,
    "size" : 633468,
    "uuid" : "21de849b-1568-3075-b33a-c85e2023e0fe",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6448300032,
    "size" : 195332,
    "uuid" : "33a7942a-7085-31b4-be35-00f98b6d4ff6",
    "path" : "\/usr\/lib\/system\/libdyld.dylib",
    "name" : "libdyld.dylib"
  "sharedCache" : {
  "base" : 6443614208,
  "size" : 5018419200,
  "uuid" : "4be683eb-134d-3b4e-8acc-31d02dbe6816"
  "vmSummary" : "ReadOnly portion of Libraries: Total=851.9M resident=0K(0%) swapped_out_or_unallocated=851.9M(100%)\nWritable regions: Total=1.2G written=402K(0%) resident=402K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nActivity Tracing                   256K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                             1.2G       26 \nMALLOC guard page                   96K        6 \nSTACK GUARD                       56.1M        7 \nStack                             11.2M        7 \nVM_ALLOCATE                        912K        1 \n__AUTH                             822K      161 \n__AUTH_CONST                      12.8M      295 \n__DATA                            20.1M      281 \n__DATA_CONST                      11.4M      299 \n__DATA_DIRTY                       452K       88 \n__FONT_DATA                        2352        1 \n__LINKEDIT                       620.4M        5 \n__OBJC_RO                         61.3M        1 \n__OBJC_RW                         2391K        1 \n__TEXT                           231.5M      308 \n__TPRO_CONST                       128K        2 \nmapped file                       32.5M        2 \npage table in kernel               402K        1 \nshared memory                      192K        6 \n===========                     =======  ======= \nTOTAL                              2.2G     1500 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "logWritingSignature" : "656b96068b4de3e6de57f56a0c0a78dd54e76ac1",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "63508950b3714d3622fc77f7",
      "factorPackIds" : {
        "SIRI_MEMORY_SYNC_CONFIG" : "651ef5f9d0c9ce2f459b5326"
      "deploymentId" : 250000012
      "rolloutId" : "6761d0c9df60af01adb250fb",
      "factorPackIds" : {
      "deploymentId" : 250000004
  "experiments" : [
      "treatmentId" : "993c66e1-bf83-41fd-a09f-0d8d5906d223",
      "experimentId" : "664fc3cd79a61a0b8b557292",
      "deploymentId" : 500000013
LemonMeringueTy
#37 Post by LemonMeringueTy » Sat Mar 15, 2025 5:46 am
Devs please respond :(
#38 Post by Woodstock » Sat Mar 15, 2025 7:10 pm
The "Devs" (there is only one for MakeMKV) shows up every couple of months to update the beta key, and when there is something to announce.
If you're waiting for Apple devs to announce fixing what they broke, they have a different place for such postings.
arcticleo
#39 Post by arcticleo » Sat Mar 15, 2025 9:02 pm
Oh, Apple tend to be immovable in situations like this when they change something that break indie apps. I don’t expect them to do anything to help.
I’m super bummed about this as MakeMKV has broken for me as well. I hope to hear from the developer eventually if these changes are possible to work around or if MakeMKV on macOS is effectively defunct.
What are the MakeMKV alternatives for macOS, if any?
lovemyflicks
#40 Post by lovemyflicks » Sun Mar 16, 2025 4:38 pm
FYI: As a temporary get around, I'm running a Windows 11 Virtual machine using Parallels. Makemkv for Windows works fine in that environment. Just a few extra steps. Definitely prefer to run it native on the mac.
LemonMeringueTy
#41 Post by LemonMeringueTy » Sun Mar 16, 2025 7:34 pm
Woodstock wrote: Sat Mar 15, 2025 7:10 pm The "Devs" (there is only one for MakeMKV) shows up every couple of months to update the beta key, and when there is something to announce.
So for those of us who paid for the product that no longer works, we're just SOL?
Fantastic.
LemonMeringueTy
#42 Post by LemonMeringueTy » Sun Mar 16, 2025 7:35 pm
lovemyflicks wrote: Sun Mar 16, 2025 4:38 pm FYI: As a temporary get around, I'm running a Windows 11 Virtual machine using Parallels. Makemkv for Windows works fine in that environment. Just a few extra steps. Definitely prefer to run it native on the mac.
I've tried this as well, but I keep getting the occasional SCSI error, and 4K's will not read whatsoever.
Everything was fine in the MacOS version.
arcticleo
#43 Post by arcticleo » Mon Mar 17, 2025 1:09 am
LemonMeringueTy wrote: Sun Mar 16, 2025 7:34 pm
Fantastic.
Not necessarily.
Beta versions of operating systems break apps from time to time. This is why beta OSs should not be installed on people's daily drivers.
As far as the developer(s) of MakeMKV is concerned, there's no way for them to immediately know if this is a temporary regression in the 15.4 beta that will be fixed in an upcoming release, or if it's something that will remain broken when 15.4 is officially released and needs to be worked around. I'm sure they would love to know which, to know whether they need to find a workaround or not. I'd be surprised if they're not actively researching this to find out.
I've also paid for MakeMKV, and I too am also eager for it to work again. But as long as I, like you, choose to live on the bleeding breaking edge with OS betas, we bear some blame for it being broken for us and can't assume it to be fixed overnight.
LemonMeringueTy
#44 Post by LemonMeringueTy » Mon Mar 17, 2025 1:21 am
arcticleo wrote: Mon Mar 17, 2025 1:09 am
Fantastic.
Not necessarily.
Fair enough.
I guess it's a wait-and-see until 15.4 is out of beta.
arcticleo
#45 Post by arcticleo » Mon Mar 17, 2025 1:47 am
LemonMeringueTy wrote: Mon Mar 17, 2025 1:21 am Fair enough.
Yes. I agree that it'd be nice to know whether the developer is aware of this situation or not. And keeping this thread active is us doing our part, as I see it. 😊
