#10756 Post by RESET_9999 » Wed Mar 12, 2025 3:43 am
When in doubt, it's probably safer to use generated DV rpu or watch in HDR10.
deadchip12
#10757 Post by deadchip12 » Thu Mar 13, 2025 2:26 am
@RESET_9999
I just rewatched your "Transfer CMv 4.0 Dolby Vision from WEB streaming to Profile 7 Bluray disc" video and it only took you less than 2 minutes to extract the rpu from a movie? How is that possible? Mine took like more than an hour.
#10758 Post by RESET_9999 » Thu Mar 13, 2025 2:35 am
My PC has fast 7gb/s gen4 nvme drives
https://www.amazon.com/WD_BLACK-SN770-I ... r=8-3&th=1
HotFudge
#10759 Post by HotFudge » Sat Mar 15, 2025 6:38 am
Hi Reset
Quick question regarding NVidia Shield Pro w.r.t v2.9 and v4.0
Resolve generates automatic L2 100,600,1000 v2.9 compatible trims
but the L8 100 trim equivalent in v4.0 is "empty" (set to 2048).
Will my Shield Pro take the L2 trims? or does it use the "empty" L8 trim.
#10760 Post by RESET_9999 » Sat Mar 15, 2025 12:50 pm
Hi Reset
If your TV also supports cmv4.0, it won't use the L2 trims. The generated cmv2.9 L2 trims are here just to match the newer/updated cmv4.0 algo on cmv2.9 devices; you don't want your player/TV to use them.
see: https://www.youtube.com/watch?v=15HTaR0hRvI
HotFudge
#10761 Post by HotFudge » Sat Mar 15, 2025 2:52 pm
Hi Reset
Thanks for your answer
So the L8 trim is used to make manual adjustments to the L2 trims
which are used aslong as it is all in v4.0.
Do you also maintain a list of v2.9 and v4.0 devices and TV's
#10762 Post by RESET_9999 » Sat Mar 15, 2025 3:07 pm
No, but any hardware made after 2019 should have the cmv4.0 engine
HotFudge
#10763 Post by HotFudge » Sat Mar 15, 2025 3:38 pm
Many Thanks
deadchip12
#10764 Post by deadchip12 » Sat Mar 15, 2025 4:28 pm
@RESET_9999
I just did the transfer of cmv4.0 for the movie The Iron Claw (2023). Frame difference is +574. Seems pretty high. Other than that, watched the movie and there wasn't any problem.
#10765 Post by RESET_9999 » Sat Mar 15, 2025 5:41 pm
@RESET_9999
it doesn't matter how big the frame difference is. It's fine as long as your source scene cuts are in sync.
ragico
#10766 Post by ragico » Sat Mar 15, 2025 6:58 pm
@Reset_9999
Thanks very much for your hard work and help, You are among the very few men who really helps.
#10767 Post by RESET_9999 » Sat Mar 15, 2025 7:25 pm
You're welcome :)
deadchip12
#10768 Post by deadchip12 » Sun Mar 16, 2025 6:52 am
@RESET_9999
I just watched your corelect configuration tutorial. Why is L6 set to Discard instead of Source?
#10769 Post by RESET_9999 » Sun Mar 16, 2025 10:33 am
L6 is useless
HotFudge
#10770 Post by HotFudge » Sun Mar 16, 2025 12:42 pm
RESET_9999 wrote:
Fri Feb 28, 2025 10:40 pm
yes, L2 is always ignored with a cmv4.0 RPU + hardware, even without L8.
Hi Reset
So does this mean in order to use my generated DaVinci Resolve RPU
I need to save it as v2.9 for it to use the L2 generated trims since
if I save the RPU as v4.0 it will just use the "empty" L8 v4.0 trim and
ignore the L2 generated v4.0 trims?
