PM is coming.BifiMike wrote: Wed Mar 05, 2025 2:04 pm Hallo Coopervid
Bought a Verbatim drive with the following info:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ...
Firmware-Datum: 2020-06-15
Highest AACS version: 35
Drive platform: RS8511
Firmware version: 1.14
Is it possible to read/rip UHD like the others posted here? Many thanks in advance
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Got it, will do and report back. Thanks again for the fast replyCoopervid wrote: Wed Mar 05, 2025 7:28 pmPM is coming.BifiMike wrote: Wed Mar 05, 2025 2:04 pm Hallo Coopervid
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
Ah, now makemkv detects my drive (problem was not loaded sg kernel module).
I have (as it looks like many others) the portable verbatim one
OS-Gerätename: /dev/sr0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
Highest AACS version: 68
PM sent.qupfer wrote: Mon Mar 10, 2025 6:47 pm Ah, now makemkv detects my drive (problem was not loaded sg kernel module).
Laufwerksinformation OS-Gerätename: /dev/sr0 Aktuelles Profil: BD-ROM Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.14 Serienummer: ... Firmware-Datum: 2020-06-15 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Thank you so much! I was able to rip 4k UHD. I donated some. Enjoy a coffee or tea.Coopervid wrote: Sat Mar 01, 2025 8:24 pmPM sent.jusinlee wrote: Wed Feb 19, 2025 7:52 am Hi Coopervid,
I bought a Verbatim drive (BD-RW BDR-UD03) and a MakeMKV license key.
Here is the drive info:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DL
Firmware date: 2020-06-15
Highest AACS version: 81
Would you be able to send me the firmware?
I will come back
Thanks.
Merci, will report of success in a few days. (need a windows first
telefax.mousier-6p
Hello, I recently bought an ASUS SBW-06D5H-U and thought it can read 4K UHD too (even though it's BDXL compatible). Is there a firmware that can unlock the external drive?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: xxx
Firmware date: 2018-08-22
Firmware version: E101/ID26
Hi Coopervid,
Could I also get help with this drive?
OS device name: F:
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Firmware version: 1.10
Unrestricted read speed: YesRe: Pioneer BDR-UD03 UHD possibility
PM sent.pho604 wrote: Fri Mar 14, 2025 6:00 pm Hi Coopervid,
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.10 Serial number: Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.10 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hey I recently bought a Verbatim external Slim drive. Makemkv give me the information its also a BDR-UD03 1.14. I cannot open Blu Rays of b Region. Can you help me with this?
PM sent.mkjonny wrote: Sat Mar 15, 2025 1:57 pm Hey I recently bought a Verbatim external Slim drive. Makemkv give me the information its also a BDR-UD03 1.14. I cannot open Blu Rays of b Region. Can you help me with this?
Hello Coopervid,
My drive has the following information. Please let me know what is required to get this to work with MKV+UHDs.
Thanks in advance.
Thanks in advance.
Revision: 1.03
Serial number: PIDxxxxxxxx
Firmware date: 2015-05-14
Highest AACS version: 77
Drive platform: RS8510
Firmware version: 1.03/ID19
PM sent.razer wrote: Sat Mar 15, 2025 7:53 pm Hello Coopervid,
Thanks in advance.
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.03 Serial number: PIDxxxxxxxx Firmware date: 2015-05-14 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
RetroMasterUser
Hello Coopervid,
i have came recently to the conclusion that the ODD´s have had it´s peak and are now beyond.
News about the discontinuation of Blu-ray disc production for consumers (Sony) and Blu-ray players (LG) drew my attention back to my external drive, which I had almost forgotten about and barely used.
And guess what? It's a BD-RW BDR-UD03 with the Verbatim logo on it. Bouht it years ago. I couldn´t believe it as makemkv told me so and even more as i come to read your thread here, becoming aware of the possibility that it might read UHD Discs.
Thank you very much.
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.05
Serienummer: ...
Firmware-Datum: 2015-11-24
Firmware version: 1.05
PM sent.RetroMasterUser wrote: Sat Mar 15, 2025 10:52 pm Hello Coopervid,
And guess what? It's a BD-RW BDR-UD03 with the Verbatim logo on it. Bouht it years ago. I couldn´t believe it as makemkv told me so and even more as i come to read your thread here, becoming aware of the possibility that it might read UHD Discs.![]()
Laufwerksinformation OS-Gerätename: D: Aktuelles Profil: BD-ROM Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.05 Serienummer: ... Firmware-Datum: 2015-11-24 Markierungen der Bus-Verschlüsselung: 1B LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.05 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
