Debug log started at Tue Feb 04 02:09:57 2025 , written by MakeMKV v1.17.9 win(x64-release)
001005:0000 MakeMKV v1.17.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Valium/MakeMKV_log.txt
No SDF v098: HL-DT-ST_DVDRAM_GH24LS50_YP01_20090522123456_K3F9C283944
DEBUG: Code 0 at uz/k3ZoD[JF-EP`c<:29396253
DEBUG: Code 0 at F~av>g3BOE]Z4$,%:213136746
DEBUG: Code 3 at p3dF_g|OCYM]UJKb%>GKhPFX:29395310
SDF id v098: HL-DT-ST_DVDRAM_GH24LS50_YP01_20090522123456_K3F9C283944
003042:0000 IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 118095996 at "DErjUX2=qykSB3wOjJ|9/(:29394183
001003:0020 DEBUG: Code 0 at "DErjUX2=qykSB3wOjJ|9/(:121263590
001003:0020 DEBUG: Code 0 at yWvq[xyG[mzH&[Gf2io$:29394689
001003:0020 DEBUG: Code 3221225649 at (Wd;Bs`q"=u.Z.K)hL.e%sH:29394919
001003:0020 DEBUG: Code 3221225649 at "DErjUX2=qykSB3wOjJ|9/(:213130145
001003:0020 DEBUG: Code 3221225480 at (Wd;Bs`q"=u.Z.K)hL.e%sH:121262509
001003:0020 DEBUG: Code 3221225480 at "DErjUX2=qykSB3wOjJ|9/(:29394183
001003:0020 DEBUG: Code 0 at mZu6gl45NB#7Hg:29397104
003013:0000 Title #0 with special attributes was skipped
003013:0000 Title #1 with special attributes was skipped
003013:0000 Title #2 with special attributes was skipped
003013:0000 Title #3 with special attributes was skipped
003013:0000 Title #4 with special attributes was skipped
003013:0000 Title #5 with special attributes was skipped
003013:0000 Title #6 with special attributes was skipped
003013:0000 Title #7 with special attributes was skipped
003013:0000 Title #8 with special attributes was skipped
003013:0000 Title #9 with special attributes was skipped
003025:0000 Title #11 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Application exited at Tue Feb 04 02:11:58 2025Code: Select all
Debug log started at Tue Feb 04 02:17:59 2025 , written by MakeMKV v1.17.9 win(x64-release)
005072:0000 Backing up disc into folder "file://C:/Users/Valium/Videos/backup/DO_IT_YOURSELF.iso"
001003:0020 DEBUG: Code 0 at r79-F\`Qopn&7y,}?R%):121266097
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Tue Feb 04 02:20:09 2025I'd like to create a single MKV file in order to record a portion of it with VLC because the faulty playback makes it quite difficult to do that when directly opening ISO or VOBs.
Anyone who can help me sort things out?
Thank you in advance
