telefax.mousier-6p
Post by telefax.mousier-6p »
Hello, I recently bought a blu ray drive and thought it can directly read 4k blu ray disks. It's pretty new, with an usb c port and cost like 100€ on amazon. Yesterday I found out that it can only read normal blu ray disks. Even though it's BDXL compatible which is very disappointing because it's new and not cheap.
So my question is if it's possible to flash the firmware to read 4k disks. I did some research and found that I can try to crossflash from BDR-US03 to BDR-US04. But I cannot find any firmware...
Here my info:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: xxx
Firmware date: 2018-08-22
Highest AACS version: 68
Drive platform: RS8511
Firmware version: E101/ID26
telefax.mousier-6p wrote: Fri Mar 14, 2025 6:18 pm Hello, I recently bought a blu ray drive and thought it can directly read 4k blu ray disks. It's pretty new, with an usb c port and cost like 100€ on amazon. Yesterday I found out that it can only read normal blu ray disks. Even though it's BDXL compatible which is very disappointing because it's new and not cheap.
Here my info:
Manufacturer: ASUS
Revision: E101
Serial number: xxx
PM sent.
telefax.mousier-6p
Coopervid wrote: Fri Mar 14, 2025 7:43 pm
Here my info:
Manufacturer: ASUS
Revision: E101
Serial number: xxx
PM sent.
Thank you very much. Crossflashing was straightforward and 4K disks are now readable! I got some issues with playing disks directly via VLC on macOS. I think it's not possible with this drive. But most important is that I don't need to buy another drive even though it's limited to 4x like in the UHD Disk Guide. But I think it's okay.
Is it possible to flash directly in macOS with Apple Silicon? If yes I could create a short manual.
telefax.mousier-6p
This is my portable setup lol:
The firmware files are Windows only by the author. No options therefore.
GDZsobi
Post by GDZsobi »
I'm currently experiencing an issue similar to what is described in this post, my drive is unable to read 4K Blu-ray disk. It is the same model as mentioned in this post, but it has a newer firmware version, as I shown below.
OS device name: E:
Manufacturer: ASUS
Revision: E102
Serial number: CIDL279490WL
Firmware date: 2023-04-20
Highest AACS version: 76
Firmware version: ID26
Is there a way to make my drive read 4K discs?
I'd appreciate any suggestion. Thank you for your help!
GDZsobi wrote: Wed Mar 26, 2025 9:31 am I'm currently experiencing an issue similar to what is described in this post, my drive is unable to read 4K Blu-ray disk. It is the same model as mentioned in this post, but it has a newer firmware version, as I shown below.
OS device name: E:
Manufacturer: ASUS
Revision: E102
You are out of luck with firmware newer than Dec. 2022.
Gozer83
Post by Gozer83 »
Hello, i buyed this
ASUS SBW-06D5H-U BDXL Extern Ultra Slim in April 2020. Can anyone help me to read UHD with it?
I never made firmware update, so pretty sure it is possible.
all the best
zittrig
Post by zittrig »
Post your drive information with a MakeMKV screen.
Gozer83
Post by Gozer83 »
Excuse me, is that better and does it help?
zittrig
Post by zittrig »
Yes, that helps. The drive informations on the right are important.
Your drive can be flashed. Just wait a bit, someone (Billycar11 or Coopervid) can support you.
Gozer83
Post by Gozer83 »
Great, thank you very much in advance.
Gozer83 wrote: Fri Apr 04, 2025 12:59 pm Great, thank you very much in advance.
PM sent.
Gozer83
Post by Gozer83 »
Answered. Thank you very much. You guys helped me a lot.
kisses and hugs #nohomo :lol:
edmsms
Post by edmsms »
Same model: ASUS SBW-06D5H-U. It can be flashed?
