Finally got the right drive to do ripping of UHD and even playing under Mac but got corruption from the mkv.
newriderca11
#1 Post by newriderca11 » Fri Mar 14, 2025 7:45 am
Hello all Finally got the right drive to do ripping of UHD and even playing under Mac but got corruption from the mkv. BU40N Ultra Slim 9.5mm UHD 4K Blu-ray SATA 3.0 GB/s Optical Drive for PC is my drive. They have it at Amazon. I had to Flash it. BTW I went through two of uhd drive the thrid one is fantastic. After I flash it I was able to play UHD with VLC under Mac os with modification for vlc. So yes I'm able to play directly from the UHD disk. But ripping using makemkv and then playing the file i get this. Here are screen shots of firmware also a link of the drive i bought it from so people can buy from it. And a video of what it look when playing the mkv video. Hopefully someone can help me. Ty
Drive
https://www.amazon.com/dp/B07BSF41VW?re ... asin_title
Enclosure
https://www.amazon.com/dp/B09X9ZTW5D?re ... asin_title
Link of my problem playing mkv that i ripped using makemkv with a Apple Macbook Air m3
https://youtu.be/SLwCM8G72HA
Thank you all.
chrisb42
Re: Finally got the right drive to do ripping of UHD and even playing under Mac but got corruption from the mkv.
#2 Post by chrisb42 » Sun Mar 30, 2025 11:26 am
So you created an .mkv file from the movie and that's the result? For the whole file or just parts? And is that only with that disc or with every disc?
Something is definitely wrong, I don't think I've encountered that myself.
MarkM929
#3 Post by MarkM929 » Fri Apr 11, 2025 11:43 pm
How did you do the firmware update? I recently picked up the same drive and am having issues getting it to patch. My drive has current firmware version 1.02. Any assistance you can provide is appreciated.
Thanks,
Mark
newriderca11
#4 Post by newriderca11 » Sat Apr 12, 2025 3:26 am
I downloaded the firmware that was recommended through one of the thread I started I think. I didn't use my mac but I used a headless laptop. It was running Windows 11. But if you read more of how to you can do it. Just go with the how to from this forum.
newriderca11
#5 Post by newriderca11 » Sat Apr 12, 2025 3:45 am
MarkM929 wrote: Fri Apr 11, 2025 11:43 pm How did you do the firmware update? I recently picked up the same drive and am having issues getting it to patch. My drive has current firmware version 1.02. Any assistance you can provide is appreciated.
Thanks,
Mark
DE_LG_BU40N_1.03_MK.bin is firmware I used
MarkM929
#6 Post by MarkM929 » Tue Apr 15, 2025 11:49 pm
Thank you. I will give that a try.
MarkM929
#7 Post by MarkM929 » Tue Apr 15, 2025 11:51 pm
newriderca11 wrote: Sat Apr 12, 2025 3:45 am
Thanks,
Mark
Just to be clear. You patched the firmware on the drive using a PC laptop and now it will work on your mac?
