Destruction pictures of my Verbatim 43888 (Pioneer UD04)
Yethidran
Re: Destruction pictures of my Verbatim 43888 (Pioneer UD04)
#31 Post by Yethidran » Tue Feb 11, 2025 8:16 am
And so far there is no "Conflicts with using MakeMKV Software" using this cheap but good casing.
Yethidran
#32 Post by Yethidran » Tue Feb 11, 2025 8:37 am
wish i could post the side by side picture of this external casing and the verbatim casing, but i must respect the moderators here in makemkv as there is only a limited amount of bandwidth to be used in the forum. pictures do take up alot of space regarding bandwidth.
but trust me, this casing is nice and very usable.
#33 Post by Billycar11 » Tue Feb 11, 2025 11:17 am
Yethidran wrote: Tue Feb 11, 2025 8:37 am wish i could post the side by side picture of this external casing and the verbatim casing, but i must respect the moderators here in makemkv as there is only a limited amount of bandwidth to be used in the forum. pictures do take up alot of space regarding bandwidth.
imgur and imbed it with the image insert
must be direct to photo only right click open image and new tab and use that URL
Yethidran
#34 Post by Yethidran » Tue Feb 11, 2025 11:28 am
thanks buddy.
razer
#35 Post by razer » Wed Mar 12, 2025 4:27 pm
@Yethidran, do you have any tips on opening this Verbatim case?
Thanks in advance.
Yethidran
#36 Post by Yethidran » Thu Mar 13, 2025 2:49 am
sadly no tips at all on how to open up this casing, other than forcibly destroying the casing. i actually found in "Reddit" that one person posted pictures of this casing and saying that there are 2 small holes at each side of the casing to pry it open. i tried that, but no success at all. so i just forcibly broke open the casing. sorry buddy.
DavoBR
#37 Post by DavoBR » Thu Mar 13, 2025 8:24 am
Yethidran
#38 Post by Yethidran » Fri Mar 14, 2025 3:16 am
yes, thats the correct link. i pushed, pulled, poked, but no success.
razer
#39 Post by razer » Fri Mar 14, 2025 9:27 pm
Thanks for the link. I'll try my luck and see how far I want to go before smashing this on the floor in frustration!
#40 Post by Coopervid » Fri Mar 14, 2025 9:41 pm
razer wrote: Fri Mar 14, 2025 9:27 pm Thanks for the link. I'll try my luck and see how far I want to go before smashing this on the floor in frustration!
Just be careful. I'm sure there some snaps and it it possible to disassemle without breaking th enclosure.
razer
#41 Post by razer » Sat Mar 15, 2025 11:39 pm
Mission accomplished. I was able to disassemble the case without too much damage.
Removed the LG drive, and dropped in a Pioneer drive.
Thanks for making this so difficult Pioneer.
Yethidran
#42 Post by Yethidran » Sun Mar 16, 2025 1:30 am
thats cool buddy!!
you managed to pry open the casing without any visible damage.
but i guess it took alot of calm and patience on your side.
anyway, congratulation's.
cheers.
