Best programs for editing subtitles?
Bsmooth
Post by Bsmooth » Thu Mar 13, 2025 4:13 pm
I like I can switch them on and off on a bluray. But on a MKV file its not so easy, sometime I just have to leave them on or have them forced just to see them. If thats the case whats the best software to adjust there size and position without screwing around with the sync of them to the video. Sometimes they are huge and I would like them to be as unobtrusive as possible.
bmillham
Re: Best programs for editing subtitles?
Post by bmillham » Thu Mar 13, 2025 9:33 pm
MKVToolNix will allow you to change the flags on the subtitles so they are forced or optional.
Bsmooth
Post by Bsmooth » Thu Mar 13, 2025 11:49 pm
Just looking for an easy to use program to maybe reduce the size of the Subtitle and put them a little lower. MKVToolNix I have to admit is not the easiest thing to use, although I haven't had a lot of time to use it.
Post by dcoke22 » Fri Mar 14, 2025 12:09 am
Some players have controls and settings for where subtitles are displayed. Might want to start there.
charlie2025
Post by charlie2025 » Tue Jun 03, 2025 12:46 am
I came across software called Subtitle Edit. I've used it to compare subtitle tracks when there are multiples. Don't know if it will do what you need but it is free, open source.
Bsmooth
Post by Bsmooth » Tue Jun 03, 2025 1:31 am
Yes you are quite right, I got Subtitle Edit as well and so far its been working great. Very easy to use and above all its very fast too.
VA1DER
Post by VA1DER » Wed Jun 04, 2025 5:14 pm
Some players (Roku for example) don't support Blu-Ray's raster subtitle format. I use MKV Subtitle Convertor to OCR them into text formats that my Roku does support. It is a little bit of a process to set up, as you need to also install Tesseract OCR and download language files for each language you want it to support. But once done I've found this to be the best subtitle OCR I've used. Better then any online convertor.
