Verbatim 43888 reads normal Blu-Ray fine, AACS/LibreDrive issues with UHD...
standard_output
Post by standard_output »
The drive is able to read normal Blu-Ray and 4K/UHD discs (e.g. listing contents) without issue.
MakeMKV is able to properly process normal Blu-Ray discs without issue.
All 4K/UHD discs that I have tried result in comparable failures, as described below.
I suspect the next step is drive flashing, or perhaps waiting for MakeMKV to put out a patch - not really sure. Any help appreciated.
MakeMKV v1.17.9 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as ...
The physical drive is labeled as a Verbatim 43888. The disc under test is labeled as a 4K/UHD disc. MakeMKV outputs this information:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 76
Disc Information
Label: THE HOBBIT AUJ EXT
Timestamp: 2020-09-17 21:24:31
Protection: AACS2.0/C v76
Data capacity: 77.57 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Verbatim 43888 reads normal Blu-Ray fine, AACS/LibreDrive issues with UHD...
You need to flash it. BU40N 1.03 is recommended.
viewtopic.php?f=16&t=19634
