#10756 Post by RESET_9999 » Tue Mar 11, 2025 12:11 pm
Another DV thing I noticed recently. If L5 is missing, the trim's positive lift is ignored on the TVs internal player (and energy player). So it means positive lift will not work for all the AppleTV web-dl on TVs internal player. On the ugoos, it doesn't matter because CPM build generates L5 when it's missing. On all the other HDMI devices, it's always ignored regardless of L5, so positive lift never works.
Positive lift test files:
missing L5: https://drive.google.com/file/d/1QvEgEE ... drive_link
proper L5: https://drive.google.com/file/d/1pQYCYs ... drive_link
L5 set to 0: https://drive.google.com/file/d/1pQYCYs ... drive_link
daffie
#10757 Post by daffie » Tue Mar 11, 2025 4:07 pm
So CPM build always generates L5 - even when it's missing L5 ?
What does it generate exactly ? Does it use 0 (zero) value in those cases ?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
#10758 Post by RESET_9999 » Tue Mar 11, 2025 4:25 pm
Yes, it sets L5 to zero when missing.
The fact that Positive lift doesn't work is proof that a release without L5 is wrong.
Zetph wrote:
Tue Mar 11, 2025 5:09 am
I'm confused, genuinely as I don't know if this is a specific topic for something or if there is something to learn.
I've always used makemkv for movies so far, and have always had DoVi and Atmos support withing the mkv container and just Jellyfin on Shield. Using a Hisense w/ eArc.
Is there something I should be aware of in the future when I want to upgrade to an LG or similar? Seems from the comments the answer is yes.
Or is this about reducing the disc size down and maintaining it? :?
Do yourself a favor and get the ugoos am6b+. No other player can match its DV quality/capabilities.
deadchip12
#10759 Post by deadchip12 » Tue Mar 11, 2025 4:41 pm
RESET_9999 wrote:
Mon Mar 10, 2025 10:38 am
xml input auto edit l6
I finished adding DV to Avengers Endgame using your best version rpu. Watched the movie and there wasn't any issue. So should it be removed from the Not Sure! yellow table now?
#10760 Post by RESET_9999 » Tue Mar 11, 2025 4:46 pm
You won't notice any visual defect or anything but when the metadata does not match the BL actual brightness, over-dimming will happen, and unless you know exactly how a specific shot is supposed to look, you won't notice anything wrong.
I explained and showed what would happen and why it is important to check the grades when doing P8 hybrid from two sources.
https://www.youtube.com/watch?v=236athosits
deadchip12
#10761 Post by deadchip12 » Wed Mar 12, 2025 12:23 am
I see. So will you recommend me continue doing this? Because i'm considering it for the few Chris Nolan movies. They are all hdr10 and in the yellow table.
#10762 Post by RESET_9999 » Wed Mar 12, 2025 3:43 am
When in doubt, it's probably safer to use generated DV rpu or watch in HDR10.
deadchip12
#10763 Post by deadchip12 » Thu Mar 13, 2025 2:26 am
@RESET_9999
I just rewatched your "Transfer CMv 4.0 Dolby Vision from WEB streaming to Profile 7 Bluray disc" video and it only took you less than 2 minutes to extract the rpu from a movie? How is that possible? Mine took like more than an hour.
#10764 Post by RESET_9999 » Thu Mar 13, 2025 2:35 am
My PC has fast 7gb/s gen4 nvme drives
https://www.amazon.com/WD_BLACK-SN770-I ... r=8-3&th=1
HotFudge
#10765 Post by HotFudge » Sat Mar 15, 2025 6:38 am
Hi Reset
Quick question regarding NVidia Shield Pro w.r.t v2.9 and v4.0
Resolve generates automatic L2 100,600,1000 v2.9 compatible trims
but the L8 100 trim equivalent in v4.0 is "empty" (set to 2048).
Will my Shield Pro take the L2 trims? or does it use the "empty" L8 trim.
#10766 Post by RESET_9999 » Sat Mar 15, 2025 12:50 pm
Hi Reset
If your TV also supports cmv4.0, it won't use the L2 trims. The generated cmv2.9 L2 trims are here just to match the newer/updated cmv4.0 algo on cmv2.9 devices; you don't want your player/TV to use them.
see: https://www.youtube.com/watch?v=15HTaR0hRvI
HotFudge
#10767 Post by HotFudge » Sat Mar 15, 2025 2:52 pm
Hi Reset
Thanks for your answer
So the L8 trim is used to make manual adjustments to the L2 trims
which are used aslong as it is all in v4.0.
Do you also maintain a list of v2.9 and v4.0 devices and TV's
#10768 Post by RESET_9999 » Sat Mar 15, 2025 3:07 pm
No, but any hardware made after 2019 should have the cmv4.0 engine
HotFudge
#10769 Post by HotFudge » Sat Mar 15, 2025 3:38 pm
Many Thanks
deadchip12
#10770 Post by deadchip12 » Sat Mar 15, 2025 4:28 pm
@RESET_9999
I just did the transfer of cmv4.0 for the movie The Iron Claw (2023). Frame difference is +574. Seems pretty high. Other than that, watched the movie and there wasn't any problem.
