anyway, i hope i didnt come across rude. just stating my position
Is my pioneer BDR-XD05s flashable?
pitt1717
Re: Is my pioneer BDR-XD05s flashable?
pitt1717
ok, guess i have to make 1 more. pm sent
jaimelalone
just another someone wanting to flash a drive...
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: PKDLxxxxxxUC
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
PM sent.jaimelalone wrote: Sat Feb 22, 2025 10:41 pm just another someone wanting to flash a drive...Drive Information
Revision: 3.10
bragger3001
Here is my MakeMKV info:
Revision: 3.10
Serial number: ,,,
Highest AACS version: 61
PM sent.bragger3001 wrote: Sat Mar 08, 2025 4:41 am
Revision: 3.10
Serial number: ,,,
bragger3001
I want to say thank you so much and verify that everything is working great as far as I can tell so far! Great work!Coopervid wrote: Mon Mar 10, 2025 8:17 pmPM sent.bragger3001 wrote: Sat Mar 08, 2025 4:41 am
Revision: 3.10
Serial number: ,,,
bragger3001
Donation sentbragger3001 wrote: Tue Mar 11, 2025 4:19 amI want to say thank you so much and verify that everything is working great as far as I can tell so far! Great work!Coopervid wrote: Mon Mar 10, 2025 8:17 pmPM sent.bragger3001 wrote: Sat Mar 08, 2025 4:41 am
Revision: 3.10
Serial number: ,,,
Thank you!
Powerkey
Thank you, that worked great.
Does the flasher change anything in regard to region encoded Blu-ray discs?
I just purchased a European 4k Blu-ray Disc that comes with a Region B supplemental disc. Wondering if it will RIP it.
Makemkv takes care of the region restrictions. Post your Makemkv info.Powerkey wrote: Sun Mar 16, 2025 4:25 pm Thank you, that worked great.
olditguy2025
I found this thread in a search and this is my first post on the forum. I too have this drive and checked it last night. It is working and still has the original firmware. I would like to flash it so it can read 4K discs. Can someone provide a link to the firmware for this drive?
Xrider
Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Informations lecteur
Nom du lecteur SE : E:
Fabricant : PIONEER
Produit : BD-RW BDR-XD05
Révision : 3.10
Date micrologiciel : 2017-06-22
Marqueurs d'encryptage bus : 1B
Fabricant : PIONEER
Révision : 3.10
PM sent.Xrider wrote: Wed Apr 02, 2025 7:10 pm Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Fabricant : PIONEER
Révision : 3.10
SecurityDevice
Wow, I am a total dummy. After getting a new computer, I was updating many things, and I saw there was new firmware available for my BDR-XD05S (manufactured March 2018). I did not do enough research beforehand, and immediately regretted my haste to "upgrade". This drive is no longer able to rip UHD BDs. Is there really no way to restore that functionality?
Revision: 3.11
Serial number: ...
Firmware date: 2023-03-03
Highest AACS version: 68
Drive platform: Pioneer RS8232
Firmware version: ID34
