PM sent.sunday46ma wrote: Tue Mar 11, 2025 12:24 amOkay,ths info isCoopervid wrote: Mon Mar 10, 2025 5:11 pmYou need to post your Makemkv info.sunday46ma wrote: Mon Mar 10, 2025 7:48 am Hello!
I have a
ASUS BW-16D1H-U (pioneer BDR-212T,E116 version)
Can someone send me the firmware,
Thanks.Code: Select all
Drive Information OS device name: E: Manufacturer: ASUS Product: BW-16D1H-U Revision: E116 Serial number: ,,, Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: E116/ID71 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
LibreDrive for Pioneer drives
LunaBreeze
I managed to restore an old Verbatim 71097 and get it working again, but am unable to see the full details like serial number and enable LibreDrive info to see if I can crossflash it to read UHD discs... am I doing something wrong? This is my current MakeMKV info:
Manufacturer: PIONEER
Product: BD-RW BDRUD03AS
Revision: 1.10
Firmware date: 2017-04-18
Firmware version: ID23
PM sent.LunaBreeze wrote: Wed Mar 12, 2025 6:30 pm I managed to restore an old Verbatim 71097 and get it working again, but am unable to see the full details like serial number and enable LibreDrive info to see if I can crossflash it to read UHD discs... am I doing something wrong? This is my current MakeMKV info:
Drive Information Manufacturer: PIONEER Product: BD-RW BDRUD03AS Revision: 1.10 Firmware date: 2017-04-18 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID23 No disc inserted
LunaBreeze
Thank you!Coopervid wrote: Wed Mar 12, 2025 8:55 pmPM sent.LunaBreeze wrote: Wed Mar 12, 2025 6:30 pm I managed to restore an old Verbatim 71097 and get it working again, but am unable to see the full details like serial number and enable LibreDrive info to see if I can crossflash it to read UHD discs... am I doing something wrong? This is my current MakeMKV info:
Hi,MartyMcNuts wrote: Fri Feb 28, 2025 3:43 amOnly the last 2 can have libredrive enabled but I would keep the BU40N and return the WP50NB40. The Pioneer is still a good drive but the firmware is too new and can't be flashed to enable libredrive.MidwestPancakes wrote: Thu Feb 27, 2025 10:38 pm Greetings,
I do not own any UHD discs, but I would like to make my drives LibreDrive compatible. I just purchased three new bluray drives, I took the shotgun approach in hopes one might be possible.
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.02 Serial number: DDDL001758UC Firmware date: 2022-12-27 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9330 Firmware version: GENECode: Select all
Drive Information OS device name: /dev/sr1 Manufacturer: HL-DT-ST Product: BD-RE WP50NB40 Revision: 1.03 Serial number: SIM2121BG1826 Firmware date: 2121-07-08 16:09 Bus encryption flags: 17 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959Code: Select all
Drive Information OS device name: /dev/sr1 Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.05 Serial number: MOEOAMA4115 Firmware date: 2124-04-23 13:47 Bus encryption flags: 17 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
And, if you might, what is your opinion of these three? My intention was to only keep one or two and return the others. Which would you keep?
I have a BD-RE BU40N, like MidwestPancakes:
Revision: 1.05
Serial number: MO3P2DE5037
1st post ofKrondlid wrote: Thu Mar 13, 2025 8:18 pm
Is this the right place to ask which firmware and tooling should I use to flash this with LibreDrive?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.05 Serial number: MO3P2DE5037 Firmware date: 2124-04-23 13:47 Bus encryption flags: 17 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
Ultimate UHD Drives Flashing Guide Updated 2025 says:
Recommended Firmware to flash for MakeMKV:
BU40N on any Firmware directly to > BU40N 1.03MK
(HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin)
See 'Mac/linux commands to flash' section for flash instructions.
thewallace
BDE-PR1EP can it be done?
Sorry to crosspost this: I have an interesting drive out of a Epson disc publisher, a Pioneer BDE-PR1EP. I've converted a LG to UHD in the past with no issues but I'm unsure about the firmware for Pioneers. Can this model be converted? The info below is on a BD, a 4K just makes seeking noise in the tray.
Re: BDE-PR1EP can it be done?
Contact Billycar11. He will let you know what can be done with it.thewallace wrote: Wed Mar 19, 2025 2:08 am Sorry to crosspost this: I have an interesting drive out of a Epson disc publisher, a Pioneer BDE-PR1EP. I've converted a LG to UHD in the past with no issues but I'm unsure about the firmware for Pioneers. Can this model be converted? The info below is on a BD, a 4K just makes seeking noise in the tray.
thewallace
The SDF Tool said it had the wrong platform. I'll keep it as a pure BD player/writer. Oh well.
I mistakenly updated the firmware on my BDR-XD07UHD before reading not to on here. Any way to get LibreDrive to work again?
OS device name: E:
Product: BD-RW BDR-XD07U
Revision: 1.06
Serial number: TKDL004546UC
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest AACS version: 64
Drive platform: Pioneer RS8D31
Firmware version: ID05
OS device name: E:
Revision: 1.06
The SDF Tool is for LG's platform MT-1959.thewallace wrote: Wed Mar 19, 2025 1:42 pm The SDF Tool said it had the wrong platform. I'll keep it as a pure BD player/writer. Oh well.
For 4k flash for your drive you should ask Billycar11 as Marty suggested. Perhaps there's a solution.
nope sorry man its ruined for nowerocku62 wrote: Wed Mar 19, 2025 1:50 pm I mistakenly updated the firmware on my BDR-XD07UHD before reading not to on here. Any way to get LibreDrive to work again?
OS device name: E:
Revision: 1.06
Will this PIONEER drive work with LibreDrive?
Thanks.
Thanks.
Revision: 1.00
Serial number: ...
Firmware date: 2014-04-01
Drive platform: Pioneer RS8510
Disc Information
Label: BD_ROM
Timestamp: 2025-01-15 17:34:27
Protection: AACS v81
Data capacity: 8.74 Gb
Disc type: BD-ROM
Number of layers: 1
Bus encryption flags: 80
Got this Pioneer Drive but it can't read UHD disk, Normal BD and DVD work fine.
Info From MakeMKV Beta
OS device name: F:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DGDL056034WL
Firmware date: 2022-03-16
Firmware version: 1.02/ID61
OS device name: F:
Revision: 1.02
email me for the flashercesar wrote: Sat Mar 22, 2025 4:47 am Got this Pioneer Drive but it can't read UHD disk, Normal BD and DVD work fine.
OS device name: F:
Revision: 1.02
