BDR 212V UHD Guide
Rudyard
Re: BDR 212V UHD Guide
Post by Rudyard »
Coopervid wrote: Sun Mar 02, 2025 1:46 pm PM sent.
Thank you. All good :)
RaceCar
Post by RaceCar »
A friend from school told me to purchase the "Digital Pioneer BDR-212V".
He gave me software to flash the drive but I think he gave me the wrong firmware version because I see "No disc inserted" with UHD discs.
Amazon order from, RunTechMedia, Digital Pioneer BDR-212V.
Is someone able to share the correct firmware/software flash details with me? Thank you.
Currently, MKV shows me the following details:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: DCDL0*****WL
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
RaceCar wrote: Mon Mar 10, 2025 6:35 pm A friend from school told me to purchase the "Digital Pioneer BDR-212V".
Revision: 1.02
I don't see anything wrong. It should work. Let the OS read in the UHD and then start Makemkv. What does it say?
RaceCar
Post by RaceCar »
Coopervid wrote: Mon Mar 10, 2025 8:25 pm I don't see anything wrong. It should work. Let the OS read in the UHD and then start Makemkv. What does it say?
Thank you for responding.
I insert my UHD disk and I hear the drive spinning. The OS never reads my disc and File Explorer and says I need to insert a disc. I see the same in MakeMKV , "No disc inserted".
I know the UHD disc is normal and works with my friend's external Pioneer drive from Billycar. But when we use my BDR-212V , we do not get the same results.
The exact amazon model I ordered: https://www.amazon.com/dp/B08R89FN61
Would you mind sharing the firmware/software that should have been used with the BDR-212V model I ordered so I can retry?
PM sent.
RaceCar
Post by RaceCar »
Coopervid wrote: Mon Mar 10, 2025 9:26 pmPM sent.
Thank you - I followed the instructions. After removing my power source and powering back on, same result.
I tried reading a disc without MakeMKV opened and File Explorer never reads the disc.
I tried with MakeMKV and see "Disc is being loaded" and then "No disc inserted".
Do you have any further suggestions for me? Thanks again.
RaceCar wrote: Mon Mar 10, 2025 10:00 pm
Your drive is defective. I'll send you the stock firmware. Flash it and return it. Ask for a new one.
RaceCar
Post by RaceCar »
Coopervid wrote: Mon Mar 10, 2025 11:17 pm Your drive is defective. I'll send you the stock firmware. Flash it and return it. Ask for a new one.
thank you for all of your help. I must have bad luck ; (
RadMan
Post by RadMan »
Newly acquired drive from RunTechMedia, could use a hand getting it working with UHD.
Thanks in advance.
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 58
Firmware version: ID06
RadMan wrote: Sat Mar 15, 2025 1:07 am Newly acquired drive from RunTechMedia, could use a hand getting it working with UHD.
Thanks in advance.
Revision: 1.02
Serial number: ...
PM sent.
RadMan
Post by RadMan »
Many thx! Unable to reply via PM as I guess I'm too new a member.
Rudyard
Post by Rudyard »
Hello again. I've got a second Pioneer drive. At first I thought it was another BDR-212V, but alas, it happens to be a BDR-212DBK. Is there anything I can do to enable UHD on this one? Just in case, this is what MakeMKV says about the drive:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.02/ID61
Thank you in advance.
fzman1956
Post by fzman1956 »
just got this drive connected - please advise regarding flashing for libre drive- thanks!
Revision: 1.02
Serial number:
Highest AACS version: 81
Rudyard wrote: Sat Mar 22, 2025 12:44 am Hello again. I've got a second Pioneer drive. At first I thought it was another BDR-212V, but alas, it happens to be a BDR-212DBK. Is there anything I can do to enable UHD on this one? Just in case, this is what MakeMKV says about the drive:
Revision: 1.02
Serial number:
PM sent.
fzman1956 wrote: Sat Mar 22, 2025 8:18 pm just got this drive connected - please advise regarding flashing for libre drive- thanks!
Revision: 1.02
Serial number:
PM sent.
