How do you flash a UHD HP HLDS BDRE BU40N Drive?
craig11
#1 Post by craig11 » Sun Mar 09, 2025 1:54 pm
I bought this from Amazon. I don't know if it can be flashed, or do I have to return it and buy one from here. It is an external drive. Here is what shows up on Makemkv:
OS device name: F:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW43
Serial number: 7MEQVHAKKH81M6
Firmware date: 2120-11-02 14:15
Bus encryption flags: 1F
Highest AACS version: 77
It claims that it can be flashed. I downloaded the collection of firmware from here. No idea which one to use. Which one do I need? I can rip a PAL DVD, but not a 4k disc. How do I flash?
Re: How do you flash a UHD HP HLDS BDRE BU40N Drive?
#2 Post by MartyMcNuts » Sun Mar 09, 2025 9:45 pm
craig11 wrote: Sun Mar 09, 2025 1:54 pm I bought this from Amazon. I don't know if it can be flashed, or do I have to return it and buy one from here. It is an external drive. Here is what shows up on Makemkv:
OS device name: F:
Product: BDRE BU40N
Revision: BW43
Flash it with BU40N 1.03-MK firmware.
lens4k
#3 Post by lens4k » Mon Aug 11, 2025 3:57 pm
Hi. Like you I am trying to flash practically the same drive as you. Can I please arks, did you receive the correct information and are now able to flash your drive? If so could you please tell me how you did it? Many, thanks.
larhaus
#4 Post by larhaus » Sun Aug 17, 2025 12:48 am
craig11 wrote: Sun Mar 09, 2025 1:54 pm It claims that it can be flashed. I downloaded the collection of firmware from here. No idea which one to use. Which one do I need? I can rip a PAL DVD, but not a 4k disc. How do I flash?
Look at the Ultimate UHD Drives Flashing Guide for more details.
lens4k
#5 Post by lens4k » Fri Aug 22, 2025 10:00 pm
Hi. I have a HP HLDS BDRE BU40N Drive as well. I can confirm to you that I have successfully flashed the firmware of my drive and have RIPPED 'UNTIL DAWN' 4K a 2025 movie to MKV file. The firmware used is: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 (extracted from DE_LG_BU40N_1.03_MK.bin) file in the 'Slim External Drives' folder from the "All You Need Firmware Pack" folder.
I hope this helps.
