I bought this from Amazon. I don't know if it can be flashed, or do I have to return it and buy one from here. It is an external drive. Here is what shows up on Makemkv:
OS device name: F:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW43
Serial number: 7MEQVHAKKH81M6
Firmware date: 2120-11-02 14:15
Bus encryption flags: 1F
Highest AACS version: 77
It claims that it can be flashed. I downloaded the collection of firmware from here. No idea which one to use. Which one do I need? I can rip a PAL DVD, but not a 4k disc. How do I flash?
How do you flash a UHD HP HLDS BDRE BU40N Drive?
craig11
Re: How do you flash a UHD HP HLDS BDRE BU40N Drive?
Flash it with BU40N 1.03-MK firmware.craig11 wrote: Sun Mar 09, 2025 1:54 pm I bought this from Amazon. I don't know if it can be flashed, or do I have to return it and buy one from here. It is an external drive. Here is what shows up on Makemkv:
OS device name: F:
Product: BDRE BU40N
Revision: BW43
lens4k
Hi. Like you I am trying to flash practically the same drive as you. Can I please arks, did you receive the correct information and are now able to flash your drive? If so could you please tell me how you did it? Many, thanks.
larhaus
Look at the Ultimate UHD Drives Flashing Guide for more details.craig11 wrote: Sun Mar 09, 2025 1:54 pm It claims that it can be flashed. I downloaded the collection of firmware from here. No idea which one to use. Which one do I need? I can rip a PAL DVD, but not a 4k disc. How do I flash?
lens4k
Hi. I have a HP HLDS BDRE BU40N Drive as well. I can confirm to you that I have successfully flashed the firmware of my drive and have RIPPED 'UNTIL DAWN' 4K a 2025 movie to MKV file. The firmware used is: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 (extracted from DE_LG_BU40N_1.03_MK.bin) file in the 'Slim External Drives' folder from the "All You Need Firmware Pack" folder.
I hope this helps.
I hope this helps.
