Pioneer BDR-208D - "No disk" for UHD
timjohnson408
Post by timjohnson408 »
It very well could be that I'm missing something, but from what I've read on these forums, my drive should be able to read a UHD disk because it is enabled for LibreDrive. Am I wrong? Do I still need to do some extra flashing to get this to work? I have two UHD disks that just give a status of "No disk" when I put it into MakeMKV v1.17.8.
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: [redacted]
Firmware date: 2012-08-22
Bus encryption flags: 13
Highest AACS version: 64
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Re: Pioneer BDR-208D - "No disk" for UHD
timjohnson408 wrote: Fri Nov 15, 2024 1:37 pm It very well could be that I'm missing something, but from what I've read on these forums, my drive should be able to read a UHD disk because it is enabled for LibreDrive. Am I wrong? Do I still need to do some extra flashing to get this to work? I have two UHD disks that just give a status of "No disk" when I put it into MakeMKV v1.17.8.
Revision: 1.10
Read your PM.
Revision: 1.10
Libredrive does not equal UHD compatibility!!
timjohnson408
Coopervid wrote: Fri Nov 15, 2024 4:22 pm Read your PM.
I went through the tutorial but am getting "Failed to enter kernel mode." I'm on a Windows 10 PC and tried running BDRFlash as admin and also tried rebooting.
timjohnson408 wrote: Mon Nov 18, 2024 2:16 pm
Are you sure you followed the instructions by the book? And no disc in drive and tray closed?
Ezatoka
Post by Ezatoka »
timjohnson408 wrote: Fri Nov 15, 2024 1:37 pm Firmware date: 2012-08-22
isn't that usually a problem with UHD?
Ezatoka wrote: Mon Nov 18, 2024 4:33 pm
No. The limitation exists only with LG / ASUS drives. A 208 has capable hardware.
timjohnson408
Coopervid wrote: Mon Nov 18, 2024 3:58 pm Are you sure you followed the instructions by the book? And no disc in drive and tray closed?
AhhhhhhI'm an idiot. I initially read your DM about removing the disk but forgot when I got around to actually flashing it.
timjohnson408 wrote: Mon Nov 18, 2024 6:23 pm
Calm down. Others did that before and called themselves the same. Until now I had no unsuccessful attempt in the end. Happy UHD ripping!
timjohnson408
Coopervid wrote: Mon Nov 18, 2024 6:43 pm Calm down. Others did that before and called themselves the same. Until now I had no unsuccessful attempt in the end. Happy UHD ripping!
Thanks for the help! I really appreciate it!
chrisb42
Post by chrisb42 »
Found my old Pioneer 208M, is this more or less the same as a 208D? In any case, here is the drive info:
Product: BD-RW BDR-208M
Revision: 1.40
Firmware date: 2014-03-06
Highest AACS version: 81
Firmware version: 1.40/ID60
suspiciouslywherever
Post by suspiciouslywherever »
Hello, I have a PIONEER BDR-208D. It seems possible to flash for UHD. Can anyone offer assistance? Thanks!
Revision: 1.10
Serial number: [...]
Highest AACS version: 68
suspiciouslywherever wrote: Sun Mar 09, 2025 8:22 pm Hello, I have a PIONEER BDR-208D. It seems possible to flash for UHD. Can anyone offer assistance? Thanks!
Revision: 1.10
yeah just email me see below for email and reviews
jpcspeed
Post by jpcspeed »
I also have a Pioneer BD-RW BDR-208D and was wondering if you could send me the firmware file file. Thanxs Greg
jpcspeed wrote: Thu Mar 13, 2025 10:06 pm I also have a Pioneer BD-RW BDR-208D and was wondering if you could send me the same file. Thanxs Greg
Post your Makemkv info.
