It very well could be that I'm missing something, but from what I've read on these forums, my drive should be able to read a UHD disk because it is enabled for LibreDrive. Am I wrong? Do I still need to do some extra flashing to get this to work? I have two UHD disks that just give a status of "No disk" when I put it into MakeMKV v1.17.8.
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: [redacted]
Firmware date: 2012-08-22
Bus encryption flags: 13
Highest AACS version: 64
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Pioneer BDR-208D - "No disk" for UHD
Re: Pioneer BDR-208D - "No disk" for UHD
Read your PM.timjohnson408 wrote: Fri Nov 15, 2024 1:37 pm It very well could be that I'm missing something, but from what I've read on these forums, my drive should be able to read a UHD disk because it is enabled for LibreDrive. Am I wrong? Do I still need to do some extra flashing to get this to work? I have two UHD disks that just give a status of "No disk" when I put it into MakeMKV v1.17.8.
Revision: 1.10
Libredrive does not equal UHD compatibility!!timjohnson408 wrote: Fri Nov 15, 2024 1:37 pm It very well could be that I'm missing something, but from what I've read on these forums, my drive should be able to read a UHD disk because it is enabled for LibreDrive. Am I wrong? Do I still need to do some extra flashing to get this to work? I have two UHD disks that just give a status of "No disk" when I put it into MakeMKV v1.17.8.
Revision: 1.10
timjohnson408
I went through the tutorial but am getting "Failed to enter kernel mode." I'm on a Windows 10 PC and tried running BDRFlash as admin and also tried rebooting.
Are you sure you followed the instructions by the book? And no disc in drive and tray closed?timjohnson408 wrote: Mon Nov 18, 2024 2:16 pmI went through the tutorial but am getting "Failed to enter kernel mode." I'm on a Windows 10 PC and tried running BDRFlash as admin and also tried rebooting.
Ezatoka
isn't that usually a problem with UHD?
No. The limitation exists only with LG / ASUS drives. A 208 has capable hardware.
timjohnson408
AhhhhhhI'm an idiot. I initially read your DM about removing the disk but forgot when I got around to actually flashing it.Coopervid wrote: Mon Nov 18, 2024 3:58 pm Are you sure you followed the instructions by the book? And no disc in drive and tray closed?
Calm down. Others did that before and called themselves the same. Until now I had no unsuccessful attempt in the end. Happy UHD ripping!timjohnson408 wrote: Mon Nov 18, 2024 6:23 pmAhhhhhhI'm an idiot. I initially read your DM about removing the disk but forgot when I got around to actually flashing it.Coopervid wrote: Mon Nov 18, 2024 3:58 pm Are you sure you followed the instructions by the book? And no disc in drive and tray closed?
timjohnson408
Thanks for the help! I really appreciate it!Coopervid wrote: Mon Nov 18, 2024 6:43 pm Calm down. Others did that before and called themselves the same. Until now I had no unsuccessful attempt in the end. Happy UHD ripping!
chrisb42
Found my old Pioneer 208M, is this more or less the same as a 208D? In any case, here is the drive info:
Product: BD-RW BDR-208M
Revision: 1.40
Firmware date: 2014-03-06
Highest AACS version: 81
Firmware version: 1.40/ID60
Revision: 1.40
suspiciouslywherever
Hello, I have a PIONEER BDR-208D. It seems possible to flash for UHD. Can anyone offer assistance? Thanks!
Revision: 1.10
Serial number: [...]
Highest AACS version: 68
Revision: 1.10
yeah just email me see below for email and reviewssuspiciouslywherever wrote: Sun Mar 09, 2025 8:22 pm Hello, I have a PIONEER BDR-208D. It seems possible to flash for UHD. Can anyone offer assistance? Thanks!
Revision: 1.10
jpcspeed
I also have a Pioneer BD-RW BDR-208D and was wondering if you could send me the firmware file file. Thanxs Greg
Post your Makemkv info.jpcspeed wrote: Thu Mar 13, 2025 10:06 pm I also have a Pioneer BD-RW BDR-208D and was wondering if you could send me the same file. Thanxs Greg
