Asus BW-16D1X-U
BDOER_Back
Re: Asus BW-16D1X-U
#181 Post by BDOER_Back » Sun Feb 02, 2025 11:34 pm
Hi
First messagge here,
My drive:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DCDL---------
Firmware date: 2020-07-21
Firmware version: ID76
Flashing it, will support bigger discs or it's just only for ripping 4K discs?
Based on previous messagges, it seems that is possible to get it working, please I need information about how to do it.
Re: Asus BW-16D1X-U
#182 Post by Billycar11 » Mon Feb 03, 2025 12:08 am
Just send me an email with that info see below
sophonax42
Re: Asus BW-16D1X-U
#183 Post by sophonax42 » Mon Feb 03, 2025 9:17 am
Coopervid wrote: Fri Jan 31, 2025 9:22 pm
sophonax42 wrote: Fri Jan 31, 2025 2:28 pm I have this:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
Highest AACS version: 76
PM sent.
Yes, please send next PM
kstack34
Re: Asus BW-16D1X-U
#184 Post by kstack34 » Tue Mar 04, 2025 7:43 pm
Good afternoon!
To anyone that can help, i also just recieved a BW-16D1x-U and am looking for the easiest way to flash. here is my info:
Manufacturer: ASUS
Product: BW-16D1x-U
Revision: A105
Serial Number: ...
Firmware date: 2120-12-02
Bus Encryption flags: 1F
Status: Possible, Not yet enabled
Drive platform: MT 1959
zittrig
Re: Asus BW-16D1X-U
#185 Post by zittrig » Tue Mar 04, 2025 7:58 pm
You can flash it by yourself with the SDFToolFlasher to
BW-16D1H-U A204
or
BW-16D1HT
You can find all you need there -----> viewtopic.php?f=16&t=19634
kstack34
Re: Asus BW-16D1X-U
#186 Post by kstack34 » Wed Mar 05, 2025 1:04 am
zittrig wrote: Tue Mar 04, 2025 7:58 pm You can flash it by yourself with the SDFToolFlasher to
BW-16D1H-U A204
or
BW-16D1HT
ok thanks! i was getting alittle confused between posts because of the time discrepencies between posts that i was reading and different meathods etc. ill give it a shot
SomethingElse
Re: Asus BW-16D1X-U
#187 Post by SomethingElse » Sat Mar 08, 2025 6:46 pm
I am able to flash myself, but unsure on what firmware I need to use:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ---
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Thanks in advance for any help!
zittrig
Re: Asus BW-16D1X-U
#188 Post by zittrig » Sun Mar 09, 2025 5:53 am
Have a look directly above your post. Same situation. :wink:
ZoboZodiac
Re: Asus BW-16D1X-U
#189 Post by ZoboZodiac » Sun Mar 09, 2025 12:54 pm
Hi, I've got an ASUS BW-16D 1X-U drive and it doesn't recognise UHD discs.
I'm happy to run commands myself but the information online is confusing and conflicting, so I'm not sure what to run to get my drive working correctly.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 68
Could someone please help me set this up?
Re: Asus BW-16D1X-U
#190 Post by Billycar11 » Mon Mar 10, 2025 5:35 am
ZoboZodiac wrote: Sun Mar 09, 2025 12:54 pm Hi, I've got an ASUS BW-16D 1X-U drive and it doesn't recognise UHD discs.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
pioneers can not be done diy
you have to email someone with the flasher
see below for pricing
gregl123
Re: Asus BW-16D1X-U
#191 Post by gregl123 » Sun Mar 23, 2025 12:01 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Highest AACS version: 17
need help trying to flash my model I'm new and completely lost
zittrig
Re: Asus BW-16D1X-U
#192 Post by zittrig » Sun Mar 23, 2025 1:57 pm
BW-16D1H-U A204
or
BW-16D1HT
SomethingElse
Re: Asus BW-16D1X-U
#193 Post by SomethingElse » Wed Mar 26, 2025 5:25 am
zittrig wrote: Sun Mar 09, 2025 5:53 am Have a look directly above your post. Same situation. :wink:
Thank you!
Ptitvert
Re: Asus BW-16D1X-U
#194 Post by Ptitvert » Mon Mar 31, 2025 7:56 pm
Hi everyone,
I've just got this drive:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DEDL111370WL
Could you help me how to "flash" or "LibreDrive" it?
Thank you very much in advance for your help.
Re: Asus BW-16D1X-U
#195 Post by Billycar11 » Mon Mar 31, 2025 7:59 pm
Ptitvert wrote: Mon Mar 31, 2025 7:56 pm Hi everyone,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
sure email me for a flasher
