I tried to follow this topic to viewtopic.php?t=33781 to update my firmware but not only LibreDrive is not enabled but additionally I am getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" . I utilized sdftool_flasher for updating firmware
Product: BD-RE BU40N
Revision: 1.05
Serial number: MODOAM85402
Highest AACS version: 77
Any help is much appreciate it
Still Cannot flash Verbatim 4338 KIAB
Re: Still Cannot flash Verbatim 4338 KIAB
You haven't flashed it. It is still on the original encrypted 1.05 firmware. Flash it to BU40N 1.03-MK and done.karadur wrote: ↑Sat Mar 08, 2025 6:50 pmI tried to follow this topic to viewtopic.php?t=33781 to update my firmware but not only LibreDrive is not enabled but additionally I am getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" . I utilized sdftool_flasher for updating firmware
Revision: 1.05
Thanks Marty, the closets firmware I could find was : HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin from The All You Need firmware pack. I used SDFTool but the drive remains at LibreDrive remains as not yet enabled
What is are you using?
How is the drive connected to the pc?
What error are you getting?
Marty
Revision: 1.05
Serial number: ...
Attempting to use MakeMkv against a UHD disc will produce the following
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\karadur/.MakeMKV/MKB20_v77_Constantine_7E82.tgz
- The drive is connected via single USB-C cable
- I used SDFtool Flasher version 1.2.0
- I point SDFtool with write option selected to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
- After the flashing the drive, MakeMkV reports the following
Revision: 1.05
Serial number: ...
The latest version of SDFtool Flasher is 1.3.6. Please visit the SDFtool Flasher thread.
If using that old version (why??) of SDFtool Flasher, you need to check the "enc" box as your drive has encrypted firmware. You should use the newer version of SDFtool Flasher as it automatically does this for you.karadur wrote: ↑Mon Mar 10, 2025 6:36 pmMarty
Revision: 1.05
Serial number: ...
Thank you everyone. The problem was older version SDFtool. Once I used the latest version , I was able to successfully flash the drive
