Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Prinz_Falafel
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Post by Prinz_Falafel »
Coopervid thx :D :D :D
I managed to do it, I had to turn on the (Force flash).
my Pioneer BDR-S09XLT is now a Pioneer BDR- S11 4K UHD :P :P
Thank you
Last edited by Prinz_Falafel on Fri Mar 14, 2025 4:34 pm, edited 9 times in total.
Prinz_Falafel
Coopervid wrote: Fri Jan 24, 2025 10:32 am
discbandit wrote: Fri Jan 24, 2025 12:24 am @Coopervid
Have an RS8600 and looking to enable UHD too. Thanks!
Info
Manufacturer: ASUS
Product: BW-12DIS-U
Revision: E401
Serial number: xxxxxxxxxxxx
Firmware date: 2013-09-10
Drive platform: RS8600
Firmware version: E401/ID44
PM sent.
Last edited by Prinz_Falafel on Sun Mar 09, 2025 11:59 pm, edited 1 time in total.
Prinz_Falafel wrote: Sat Mar 08, 2025 9:08 pm
Info
Manufacturer: ASUS
Product: BW-12DIS-U
Revision: E401
PM sent.
No. Your 209 V1 needs to be flashed to S11 V1. But I'm surely not perfect.
Dajafe
Post by Dajafe »
@Coopervid - I have a Pioneer drive and hope that you are able to help enabling UHD capabilities
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.51
Serial number: RHDL001633WL
Firmware date: 2018-05-08
Highest AACS version: 77
Drive platform: RS8601
Firmware version: 1.51/ID43
Many thanks
swinokur
Post by swinokur »
Hi there,
I have a new (to me) BDR-S09 (marked on the label as a BDR-S09XLB).
MakeMKV says:
Revision: 1.30
Serial number: (xxx)
Firmware date: 2014-12-05
Firmware version: 1.30/ID43
Can this be patched to support UHD? If I'm not patching it for UHD, is there any "better" firmware to be running?
thanks!
Dajafe wrote: Fri Mar 14, 2025 8:48 pm @Coopervid - I have a Pioneer drive and hope that you are able to help enabling UHD capabilities
OS device name: E:
Revision: 1.51
Many thanks
PM sent
swinokur wrote: Sat Mar 15, 2025 12:20 am Hi there,
MakeMKV says:
Revision: 1.30
thanks!
PM sent
swinokur
Post by swinokur »
Coopervid wrote: Sat Mar 15, 2025 7:40 pm PM sent
Thanks very much!
Dajafe
Post by Dajafe »
Coopervid wrote: Sat Mar 15, 2025 7:37 pm
OS device name: E:
Revision: 1.51
Serial number: ...
Many thanks
PM sent
Thank you soo much @Coopervid. This has worked perfectly and has now allowed me to rip Willy Wonka and Shawshank Redemption from the WB 100 years box set.
Tried 4 times using my 'newer' Asus BW-16D1HT. and even did a backup and tried to rip from that, but still failed every time. Disc read errors every time.
No issues at all with the Pioneer and it ripped both disks first time.
OS device name: E:
Product: BD-RW BDR-S11
Revision: 1.53
Firmware date: 2020-08-03
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Prinz_Falafel
Hello everyone,
I also have a Pioneer External Blu-ray Drive BDR-XS07TS
Is my Pioneer suitable for flashing for UHD reading?
Yethidran
Post by Yethidran »
sorry buddy, your firmware is too new and locked by pioneer.
Prinz_Falafel
Yethidran wrote: Mon Mar 17, 2025 3:42 pm sorry buddy, your firmware is too new and locked by pioneer.
oh ok :cry:
Prinz_Falafel wrote: Sat Mar 08, 2025 9:09 am Coopervid thx :D :D :D
Thank you
BTW. It says in CAPITAL letters to read the tutorial. What you didn't do.
swinokur
Post by swinokur »
Hey Coopervid,
Thanks again - the firmware update went without a hitch.
Is it possible to get a copy of the original BDR-209 firmware files so that I can go back to 'stock' if necessary?
thanks!
swinokur wrote: Sat Mar 15, 2025 12:20 am Firmware name: PIONEER BDR-209
PM sent
louisph
Post by louisph »
Would appreciate any help to achieve UHD capabilities...
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: XXXXXXXXXXX
Firmware date: 2017-12-21
Firmware version: E111/ID76
