(Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
Videophile
Re: (Asmcom:) Pioneer UHD 4K Drives From £117.32, Cheap Shipping, Worldwide Service, Excellent Service!!!
@Asmcom
[/quote]
We do have stock of this model. We will be working on the website Wednesday, Thursday & Friday of this week finishing final touches and testing. We hope website goes live on Friday.
Kind Regards
Asmcom
[/quote]
Great! Do I need to do anything to reserve one, so that they don’t run out, or the email request I sent will be enough?
Thank you!
[/quote]
Kind Regards
Asmcom
[/quote]
Thank you!
peu7510
Hi @asmcom sorry for insisting, when you open the website will you have stock of item 19? If you have it, it will reassure me, I didn't know you were still preparing the website.
MetAlbertR
I'm looking for a Pioneer drive which is both MakeMKV UHD friendly and is a good drive for ripping CDs. I currently have an LG BU40N in a Vantec enclosure, which is great for ripping UHDs, but is completely useless for CDs as the error correction seems to be non-existent.
Therefore, to maximise CD ripping ability, I've narrowed the choice down to two PureRead 4+ drives - either the BDR-X13E-S or the BDR-XD08EMB-S.
Apart from pure read/write speeds, does the X13E-S have any other advantages over the much more compact and practical XD08EMB-S?
My only reservation with these drives is whether PureRead 4+ has any real-world advantages over PureRead 3+ for CDs. If not, I could consider some cheaper options.
Thanks in advance to anybody that can answer my queries.
TomEd90
Hello, I'm looking to grab something for ripping a large 4k library using a 2-in-1 laptop. I was looking at the Verbatim 43888 due to its price, and working out the box, but having seen these are now arriving with LG drives i'd prefer to avoid hassle of needing to then flash it myself.
Would you be able to make a recommendation for a simple to use drive for this purpose and confirm pricing? I wasn't sure where they link to your shop was and cant find your ebay store. Many thanks, Tom
razer
Well, I just received another Verbatim 43888 with an LG drive instead of a Pioneer. This drive was ordered from amazon.de
pio87
hi Asmcom Sorry About the illness ( i know never good)
are you still planning on reopening tomorrow if so can you confirm what drives are Available as ive emailed about BDR-213EBK and it seems like a auto reply saying "unavailable" but not sure if thats the drive or yourself
thanks
thanks
Videophile
@asmcom
Also, I was wondering if the Pioneer BDR-X13E-S has a switching power supply (100-240V) or is the power adapter set to a region specific voltage? I am in the US. I would like to use this USB-B to USB-C cable:
https://www.crutchfield.com/p_703FUSBBC ... -feet.html
Could I perhaps power it through just a USB-C port (MacBook Pro). I am guessing not, but thought I’d still ask.
Thank you!
Thank you!
neroes
you can charge/power most DC things by using a usb-c power delivery cable like thisVideophile wrote: Thu Mar 06, 2025 8:51 pm @asmcom
Thank you!
https://www.adafruit.com/product/5450
and maybe an adapter head like this
https://www.adafruit.com/product/5474
but it requires the power source supports the voltage and the nessasary amount of amps
sorry to say but your mac probably doesn't, your phone charger might however
things to be aware of, it needs to be correct voltage, (it should be listed on the device)
the power poles need to match (there is usually a symbol on the power input showing which end piece and what polarity it need)
12master70
hi im a new makemkv forum user im looking for an external unit to rip 4k blu rays compatible with mac os x if possible (if not windows or linux is a daoble option ) don't know really what to look for , i just want a durable unit to be able tp make 1:1 rips and iso of my discs in a decent amount of time without errors
BitGeeker
Looking forward to the new site going online soon. Thanks for keeping us up to date.
Ash948
What will the new website address be?
Waiting patiently in the background for when its ready.
Glad your back up and running now anyway.
All the best,
Ash.
All the best,
Ash.
sauro21
pio87
they have updated their Ebay page again now away to 26th
BoomBoom
Videophile
