Kraven the Hunter 4k submitted.
JackFrost
Post by JackFrost »
MKB20_v77_Kraven_the_Hunter_2E70
Gillietalls
Re: Kraven the Hunter 4k submitted.
Post by Gillietalls »
Yeah waiting on this one myself.
keydb_helper
Post by keydb_helper »
JackFrost wrote:
Tue Mar 04, 2025 6:44 pm
A variant of Kraven the Hunter has been added to the public keydb.
I'm not sure about the corresponding MakeMKV-generated ID value, but if the SHA-1 hash of your discs Unit_Key_RO.inf file is 0x5F65F848DFC1C57BA7AB3B4BB2999FA8442E952F then it should work.
Public KeyDB Disc Submissions
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
JackFrost
Post by JackFrost »
I can confirm after pulling the latest keys my disc works.
