LibreDrive for Pioneer drives
Krawk
#1351 Post by Krawk » Tue Mar 04, 2025 6:15 pm
What exactly are they doing out there in The Scene? They must have a different flash tool because I doubt they are soldering.
#1352 Post by Coopervid » Tue Mar 04, 2025 6:57 pm
Krawk wrote: Tue Mar 04, 2025 6:15 pm What exactly are they doing out there in The Scene? They must have a different flash tool because I doubt they are soldering.
Are you are grass fed? Your post is weird.
pxlm8tr
#1353 Post by pxlm8tr » Tue Mar 04, 2025 7:19 pm
Long time lurker, I was wondering if my old drive can read UHD if flashed, and if so, how to do that. It's a Pioneer BDR-XU03 and I don't see much info on it here, thanks for any help in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number:
Firmware date: 2015-06-29
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8520
Firmware version: 1.03
#1354 Post by Coopervid » Tue Mar 04, 2025 8:11 pm
No confirmed firmware that will work for this drive.
pxlm8tr
#1355 Post by pxlm8tr » Tue Mar 04, 2025 8:20 pm
That's unfortunate, I appreciate your reply!
Roothog
#1356 Post by Roothog » Tue Mar 04, 2025 11:35 pm
Ok. Let's try this again. My new drive:
OS device name: H:
Current profile: DVD-ROM
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: xxxxxxxxxxxxxxxxxx
Firmware date: 2022-05-31
Firmware version: ID06
Any help greatly appreciated.
bohmchri@isu.edu
#1357 Post by bohmchri@isu.edu » Wed Mar 05, 2025 6:05 am
Is LibreDrive something I need to install?
#1358 Post by d00zah » Wed Mar 05, 2025 2:36 pm
bohmchri@isu.edu wrote: Wed Mar 05, 2025 6:05 am Is LibreDrive something I need to install?
What is LibreDrive?
Essentially, it bypasses restrictions imposed by a drives FW. It can allow a drive (whos HW supports UHD) to rip UHD discs.
Post the Drive Info/LibreDrive Info reported by MakeMKV & someone can tell you whether your drive is/can be supported.
bohmchri@isu.edu
#1359 Post by bohmchri@isu.edu » Thu Mar 06, 2025 4:47 am
Ok, here's my drive info. I might have put it in the wrong place before.
#1360 Post by MartyMcNuts » Thu Mar 06, 2025 6:00 am
bohmchri@isu.edu wrote: Thu Mar 06, 2025 4:47 am Ok, here's my drive info. I might have put it in the wrong place before.
Your drive has the dreaded post 11/2022 firmware as is not able to be flashed to enable libredrive nor UHD compatibility.
You won't find any new drives with the compatible pre 12/2022 firmware in any retail stores. The only way to get a libredrive enabled and UHD compatible Pioneer drive (that isn't a BDR-212V or BDR-212DBK) is from a seller on this forum.
MC3D_Real
#1361 Post by MC3D_Real » Thu Mar 06, 2025 6:29 pm
Hello!
I have a
PIONEER BD-RW BDR-UD03
with FW version 1.14 can someone send me the firmware
Thank you
#1362 Post by Coopervid » Thu Mar 06, 2025 8:36 pm
MC3D_Real wrote: Thu Mar 06, 2025 6:29 pm Hello!
I have a
Thank you
PM sent.
sunday46ma
#1363 Post by sunday46ma » Mon Mar 10, 2025 7:48 am
Hello!
I have a
ASUS BW-16D1H-U (pioneer BDR-212T,E116 version)
Can someone send me the firmware,
Thanks.
#1364 Post by Coopervid » Mon Mar 10, 2025 5:11 pm
sunday46ma wrote: Mon Mar 10, 2025 7:48 am Hello!
I have a
Thanks.
You need to post your Makemkv info.
sunday46ma
#1365 Post by sunday46ma » Tue Mar 11, 2025 12:24 am
Coopervid wrote: Mon Mar 10, 2025 5:11 pm
I have a
Thanks.
Okay,ths info is
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ,,,
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
