Asus BC-12D2HT with MTK1939
dewen
Post by dewen »
Hi :
I have Asus BC-12D2HT BD-ROM, manulfactured June 2015,
Since it’s MT1939, is it possible to flash MK’s firmware to make it UHD-compatible? If not, the original firmware is version 1.0. Can I upgrade it to MK’s 3.11 firmware, or should I just stick with the original 1.0?
Thank you !
Re: Asus BC-12D2HT with MTK1939
dewen wrote: Thu Mar 06, 2025 3:57 am Hi :
Thank you !
NO! Just No.
The hardware is not and never will be capable of UHD.
dewen
Post by dewen »
MartyMcNuts wrote: Thu Mar 06, 2025 4:03 am NO! Just No.
Thank you ! I will keep using firmware 1.0.
