file location
https://gofile.io/d/FP6kZF
Current profile: BD-R SRM
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: ...
Highest AACS version: 81
Firmware version: 1.05
Disc Information
Label: DAYS_OF_THUNDER
Timestamp: 2020-03-20 20:26:06
Protection: AACS2.0/C v72
Data capacity: 60.60 Gb
Bus encryption flags: 80
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
all files required are in https://gofile.io/d/FP6kZF
days of thunder
keydb_helper
Re: days of thunder
The FC83 variant of Days of Thunder (disc ID 0xA14A8218020CB64FD5C06D9CC6F7079CA88327AD) is already supported by the public keydb.
If you'd like to see native support in MakeMKV, I think you'll need to email the dump file to the MakeMKV team.
Public KeyDB Disc Submissions
Back_up_AZ
Re: days of thunder
i sent email informing of the files in depository all files i could access i put them on the depository because of large size . i use KEYDB.cfg and update it as often as it finds new keys i have sent a few up
Back_up_AZ
Re: days of thunder
these pictures show what disc i have been working with on Xreveal
- discs54 thru 91.jpg (453.15 KiB) Viewed 2661 times
- discs34 thru77.jpg (455.55 KiB) Viewed 2661 times
- discs 1 thru 46.jpg (448.75 KiB) Viewed 2661 times
