zittrig
Re: SDFtool Flasher
#1246 Post by zittrig » Sun Mar 02, 2025 5:49 am
Thank you Marty!
msoulier
Re: SDFtool Flasher
#1247 Post by msoulier » Sun Mar 02, 2025 11:02 am
Sadly the gui of this tool appears very small on my screen and refuses to allow itself to be increased in size.
Re: SDFtool Flasher
#1248 Post by dcoke22 » Sun Mar 02, 2025 4:43 pm
msoulier wrote: Sun Mar 02, 2025 11:02 am Sadly the gui of this tool appears very small on my screen and refuses to allow itself to be increased in size.
Did you see the note near the top of the first post in this thread?
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
built4comfort
Re: SDFtool Flasher
#1249 Post by built4comfort » Wed Mar 05, 2025 10:53 pm
Hello! I am new to this so not sure what I'm doing. Everything seems like it should work but everytime I go to flash, I get an error. I don't know if I'm just dense and not selecting the proper one or what.
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO9O3UB4727
Bus encryption flags: 1F
Highest AACS version: 64
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I saw the recommended flash version to use is "DE_LG_BU40N_1.03_MK.bin" but it gives me an error that says "Command produced error code 0x82052602".
Any help would be appreciated.
Re: SDFtool Flasher
#1250 Post by MartyMcNuts » Wed Mar 05, 2025 11:14 pm
built4comfort wrote: Wed Mar 05, 2025 10:53 pm Hello! I am new to this so not sure what I'm doing. Everything seems like it should work but everytime I go to flash, I get an error. I don't know if I'm just dense and not selecting the proper one or what.
OS device name: E:
Revision: 1.02
Ensure there is no disc in the drive and the tray is closed.
You should see a green check for both MT1959 drive platform and Encrypted firmware. If there is not a green check for encrypted firmware, click on the red X to toggle it.
Is this an Archgon?
built4comfort
Re: SDFtool Flasher
#1251 Post by built4comfort » Wed Mar 05, 2025 11:29 pm
MartyMcNuts wrote: Wed Mar 05, 2025 11:14 pm
OS device name: E:
Revision: 1.02
Is this an Archgon?
No disk and tray is closed. Green check marks on both. It sure is! I thought I saw it on the list of accepted but maybe I didn't pay close enough attention to the model?
Re: SDFtool Flasher
#1252 Post by MartyMcNuts » Wed Mar 05, 2025 11:45 pm
built4comfort wrote: Wed Mar 05, 2025 11:29 pm
OS device name: E:
Revision: 1.02
Is this an Archgon?
It should be compatible and everyhting looks right.
What USB port do you have it connected to?
What OS are you using?
Are you using the new SDFtool Flasher v1.3.6? If so, try using the previous version, v1.3.5 and see if that makes a difference.
built4comfort
Re: SDFtool Flasher
#1253 Post by built4comfort » Wed Mar 05, 2025 11:51 pm
MartyMcNuts wrote: Wed Mar 05, 2025 11:45 pm
Is this an Archgon?
I've got it connected to a USB (it's labeled 5G but it's blue port) 3.0. I'm using Windows 11. I tried it on v1.3.6 first but then tried v1.3.5. Which is when I posted here.
Re: SDFtool Flasher
#1254 Post by MartyMcNuts » Thu Mar 06, 2025 4:02 am
built4comfort wrote: Wed Mar 05, 2025 11:51 pm
Maybe try a different USB port if you can, preferable not a case port. Direct from the back of the motherboard if possible.
built4comfort
Re: SDFtool Flasher
#1255 Post by built4comfort » Thu Mar 06, 2025 10:23 pm
MartyMcNuts wrote: Thu Mar 06, 2025 4:02 am
Only port I haven't tried yet is the teal port. All have been on the motherboard. I will give it a shot, If that doesn't work then I'm just going to do a return on the player. Thanks for your suggestions!
Re: SDFtool Flasher
#1256 Post by MartyMcNuts » Thu Mar 06, 2025 11:47 pm
built4comfort wrote: Thu Mar 06, 2025 10:23 pm
Or, if possible, try to flash it using a friend's/family members Windows PC.
built4comfort
Re: SDFtool Flasher
#1257 Post by built4comfort » Wed Mar 12, 2025 9:58 pm
MartyMcNuts wrote: Thu Mar 06, 2025 11:47 pm
Nothing ended up working so I ended up returning it and I got the LG drive that I had to get an enclosure for to use the USB. It flashed first go... And so far so good. Ripping the first disc currently
1zestytogepi
Re: SDFtool Flasher
#1258 Post by 1zestytogepi » Mon Mar 17, 2025 2:51 pm
hello ive got a wp50nb40 i want to flash it, i see that i need to flash it first to WH16NS60 1.02-MK, but im not sure where to locate that firmware to flash it to. Any help would be appreciated.
Re: SDFtool Flasher
#1259 Post by Coopervid » Mon Mar 17, 2025 5:45 pm
1zestytogepi wrote: Mon Mar 17, 2025 2:51 pm hello ive got a wp50nb40 i want to flash it, i see that i need to flash it first to WH16NS60 1.02-MK, but im not sure where to locate that firmware to flash it to. Any help would be appreciated.
If it is WP50NB40 you have a slim drive. Never flash a slim drive with firmware for a full size drive and vice versa!!!!
Here is the guide.
viewtopic.php?f=16&t=19634
Re: SDFtool Flasher
#1260 Post by MartyMcNuts » Mon Mar 17, 2025 10:20 pm
No, do not flash desktop firmware to a slim drive!!!
Follow the guide for BP50NB40 in the first post of this very thread. There's even a gif showing you what to do!
