Is there a way to create an ISO file with MakeMKV?
neurocrash
#1 Post by neurocrash » Wed Mar 05, 2025 2:15 pm
Greetings,
I understand that one can read bluray contents to folders, then use another program such as ImgBurn or AnyBurn to make an ISO, but I am getting errors when doing this, and would prefer if it were possible to do this as a single procedure.
I apologize if this has been asked before, but this forum search ignores necessary search terms such as "ISO": "The following words in your search query were ignored because they are too common words"
Any help would be greatly appreciated
flojo
Re: Is there a way to create an ISO file with MakeMKV?
#2 Post by flojo » Wed Mar 05, 2025 4:06 pm
No.
neurocrash
#3 Post by neurocrash » Wed Mar 05, 2025 4:21 pm
Can anyone recommend a better way to create ISO files than with AnyBurn or ImgBurn, as I have been getting errors trying to do this with data extracted by MakeMKV.
#4 Post by Coopervid » Wed Mar 05, 2025 5:32 pm
This should work with Imgburn. You need to tell us what "errors" you are experiencing.
flojo
#5 Post by flojo » Wed Mar 05, 2025 6:33 pm
Can anyone recommend a better way ...
Use .zip instead. Zip is easily created, mounted and modifiable in any OS, unlike UDF 2.5.
Do you really need a large .iso file? Using the files and directories on file systems like ZFS or SnapRAID or Btrfs(?) is advantageous with their recovery aspects. You can put a large .iso on these filesystems, but there can only be an increase in either time, CPU and/or RAM resources if recovery is needed.
christopher2222
#6 Post by christopher2222 » Tue Mar 25, 2025 5:08 pm
Imgburn should make iso. But you might need anydvd to help it work.
