LibreDrive for Pioneer drives
Krawk
What exactly are they doing out there in The Scene? They must have a different flash tool because I doubt they are soldering.
Are you are grass fed? Your post is weird.Krawk wrote: Tue Mar 04, 2025 6:15 pm What exactly are they doing out there in The Scene? They must have a different flash tool because I doubt they are soldering.
pxlm8tr
Long time lurker, I was wondering if my old drive can read UHD if flashed, and if so, how to do that. It's a Pioneer BDR-XU03 and I don't see much info on it here, thanks for any help in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number:
Firmware date: 2015-06-29
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8520
Firmware version: 1.03
Revision: 1.03
Serial number:
No confirmed firmware that will work for this drive.
pxlm8tr
That's unfortunate, I appreciate your reply!
Roothog
Ok. Let's try this again. My new drive:
OS device name: H:
Current profile: DVD-ROM
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: xxxxxxxxxxxxxxxxxx
Firmware date: 2022-05-31
Firmware version: ID06
Any help greatly appreciated.
OS device name: H:
Revision: 1.02
bohmchri@isu.edu
Is LibreDrive something I need to install?
What is LibreDrive?
Essentially, it bypasses restrictions imposed by a drives FW. It can allow a drive (whos HW supports UHD) to rip UHD discs.
Post the Drive Info/LibreDrive Info reported by MakeMKV & someone can tell you whether your drive is/can be supported.
bohmchri@isu.edu
Ok, here's my drive info. I might have put it in the wrong place before.
Your drive has the dreaded post 11/2022 firmware as is not able to be flashed to enable libredrive nor UHD compatibility.bohmchri@isu.edu wrote: Thu Mar 06, 2025 4:47 am Ok, here's my drive info. I might have put it in the wrong place before.
You won't find any new drives with the compatible pre 12/2022 firmware in any retail stores. The only way to get a libredrive enabled and UHD compatible Pioneer drive (that isn't a BDR-212V or BDR-212DBK) is from a seller on this forum.
MC3D_Real
Hello!
I have a
PIONEER BD-RW BDR-UD03
with FW version 1.14 can someone send me the firmware
Thank you
I have a
Thank you
PM sent.MC3D_Real wrote: Thu Mar 06, 2025 6:29 pm Hello!
I have a
Thank you
sunday46ma
Hello!
I have a
ASUS BW-16D1H-U (pioneer BDR-212T,E116 version)
Can someone send me the firmware,
Thanks.
I have a
Thanks.
You need to post your Makemkv info.sunday46ma wrote: Mon Mar 10, 2025 7:48 am Hello!
I have a
Thanks.
sunday46ma
Okay,ths info isCoopervid wrote: Mon Mar 10, 2025 5:11 pmYou need to post your Makemkv info.sunday46ma wrote: Mon Mar 10, 2025 7:48 am Hello!
I have a
Thanks.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ,,,
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
