trouble with a disc
onemoke
trouble with a disc
#1 Post by onemoke » Sat Mar 01, 2025 4:47 pm
Never seen this before, don't know what it means.
A really old DVD of "The Matrix"
makemkv only retrieves what I think is the dvd index file
vlc and other products can read this disc w/o problem
Debug log started at Sat Mar 01 16:36:05 2025 , written by MakeMKV v1.17.9 win(x64-release)
001005:0000 MakeMKV v1.17.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\mwh/MakeMKV_log_1.txt
No SDF v098: hp_BDDVDRW_CH20L_BC33_20091209123456_B0IE3P1194532
DEBUG: Code 0 at uz/k3ZoD[JF-EP`c<:29396253
DEBUG: Code 0 at F~av>g3BOE]Z4$,%:213136746
DEBUG: Code 3 at p3dF_g|OCYM]UJKb%>GKhPFX:29395310
SDF id v098: hp_BDDVDRW_CH20L_BC33_20091209123456_B0IE3P1194532
Application exited at Sat Mar 01 16:39:05 2025
Re: trouble with a disc
#2 Post by dcoke22 » Sun Mar 02, 2025 4:59 pm
Does MakeMKV register that there's a disc in the drive?
onemoke
#3 Post by onemoke » Mon Mar 03, 2025 1:16 am
Oh yes see attached
Note that other applications see everything
#4 Post by dcoke22 » Mon Mar 03, 2025 5:30 am
What happens if you try the various different DVD Opening Modes MakeMKV has?
onemoke
#5 Post by onemoke » Mon Mar 03, 2025 7:03 pm
Auto
CellWalk
produce the results described
CellTrim
CellFull
produce results, look identical
for instance, 3 versions of the main feature, one 4 min longer with 99 chapters, the other 2 37 chapters. But appear identical in content, don't know what the time difference means
onemoke
#6 Post by onemoke » Mon Mar 03, 2025 10:12 pm
Part of the difference is the shorter versions start a few minutes into the feature
Not enough to explain entire difference
