I have a Pioneer BDR-X12UBK and it Plays/Rips 1080p Blurays fine under Linux, however if I put a UHD disc in it doesn't recognize the disc was put in (even though it says it supports BDXL quad layer, I tried a couple). I read you usually have to flash the firmware on a bluray drive to be able rip UHDs (not sure about just detecting a UHD disc). It's original firmware is from 2020, is it flash-able? I saw a warning about drives dated 2020. Or should I look into getting a different model drive for backing up UHD?
I'm considering buying a 4k of a film soon and unfortunately they don't bundle it with a standard bluray. I don't yet have a dedicated 4k player or even display. I'm just wanting to future-proof before it's out of print, if I do get the 4k version I'll need to play/rip it on a computer to even view it. I already have some 4k discs that have came in bundles with standard bluray, so even if I have to get another drive it's probably worth it to have the ability to back up those as well.
Can the Pioneer BDR-X12UBK be used for UHD or should I get another drive for UHDs?
Re: Can the Pioneer BDR-X12UBK be used for UHD or should I get another drive for UHDs?
To read/rip UHD it will most likely require flashing. Please post the MakeMKV drive info & libredrive info sections so we can check for you.JohnJacob wrote: ↑Mon Mar 03, 2025 8:42 amI have a Pioneer BDR-X12UBK and it Plays/Rips 1080p Blurays fine under Linux, however if I put a UHD disc in it doesn't recognize the disc was put in (even though it says it supports BDXL quad layer, I tried a couple). I read you usually have to flash the firmware on a bluray drive to be able rip UHDs (not sure about just detecting a UHD disc). It's original firmware is from 2020, is it flash-able? I saw a warning about drives dated 2020. Or should I look into getting a different model drive for backing up UHD?
Sorry for the late reply I noticed some of my WB DVDs from 2007 were failing, so I had to move some files around to have room to back up up any surviving WB DVDs. Here is the output of makemkvs drive infoMartyMcNuts wrote: ↑Mon Mar 03, 2025 11:08 pmTo read/rip UHD it will most likely require flashing. Please post the MakeMKV drive info & libredrive info sections so we can check for you.JohnJacob wrote: ↑Mon Mar 03, 2025 8:42 amI have a Pioneer BDR-X12UBK and it Plays/Rips 1080p Blurays fine under Linux, however if I put a UHD disc in it doesn't recognize the disc was put in (even though it says it supports BDXL quad layer, I tried a couple). I read you usually have to flash the firmware on a bluray drive to be able rip UHDs (not sure about just detecting a UHD disc). It's original firmware is from 2020, is it flash-able? I saw a warning about drives dated 2020. Or should I look into getting a different model drive for backing up UHD?
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-X12
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-05
Highest AACS version: 66
Drive platform: RS9000
Firmware name: PIONEER BDR-X12T
Firmware version: 1.03/ID56
Check your PM.JohnJacob wrote: ↑Thu Mar 06, 2025 12:50 amSorry for the late reply I noticed some of my WB DVDs from 2007 were failing, so I had to move some files around to have room to back up up any surviving WB DVDs. Here is the output of makemkvs drive infoMartyMcNuts wrote: ↑Mon Mar 03, 2025 11:08 pmTo read/rip UHD it will most likely require flashing. Please post the MakeMKV drive info & libredrive info sections so we can check for you.JohnJacob wrote: ↑Mon Mar 03, 2025 8:42 amI have a Pioneer BDR-X12UBK and it Plays/Rips 1080p Blurays fine under Linux, however if I put a UHD disc in it doesn't recognize the disc was put in (even though it says it supports BDXL quad layer, I tried a couple). I read you usually have to flash the firmware on a bluray drive to be able rip UHDs (not sure about just detecting a UHD disc). It's original firmware is from 2020, is it flash-able? I saw a warning about drives dated 2020. Or should I look into getting a different model drive for backing up UHD?
It's a USB Bluray drive if that makes any differenceCode: Select all
Drive Information OS device name: /dev/sr1 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-X12 Revision: 1.03 Serial number: ... Firmware date: 2020-08-05 Bus encryption flags: 1B Highest AACS version: 66 LibreDrive Information Status: Enabled Drive platform: RS9000 Firmware name: PIONEER BDR-X12T Firmware type: Original (unpatched) Firmware version: 1.03/ID56 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Just make I do it right. Is Windows 10 okay? Instructions say 95 or NT 4.0 (my laptop still has a small Window 10 partition installed, my desktop only has Debian 12). If I need a specific version of Windows is virtualbox okay or should I use qemu? (I'm more familiar with Virtualbox, but I have used qemu a bit)Coopervid wrote: ↑Thu Mar 06, 2025 8:38 pmCheck your PM.JohnJacob wrote: ↑Thu Mar 06, 2025 12:50 amSorry for the late reply I noticed some of my WB DVDs from 2007 were failing, so I had to move some files around to have room to back up up any surviving WB DVDs. Here is the output of makemkvs drive infoMartyMcNuts wrote: ↑Mon Mar 03, 2025 11:08 pm
Windows 10 is fine.JohnJacob wrote: ↑Fri Mar 07, 2025 9:12 amJust make I do it right. Is Windows 10 okay? Instructions say 95 or NT 4.0 (my laptop still has a small Window 10 partition installed, my desktop only has Debian 12). If I need a specific version of Windows is virtualbox okay or should I use qemu? (I'm more familiar with Virtualbox, but I have used qemu a bit)Coopervid wrote: ↑Thu Mar 06, 2025 8:38 pmCheck your PM.JohnJacob wrote: ↑Thu Mar 06, 2025 12:50 am
