#2776 Post by MartyMcNuts » Fri Feb 28, 2025 8:54 pm
mm13579 wrote: Fri Feb 28, 2025 2:20 am So I managed to test 1.02 and 1.03mk firmware with my BU40N drive and can get it to show the UHD disc now but when I click it it runs and gets error see screenshot. It does not make any sense. But it does DVD and Blu ray just fine it is just messed up for UHD discs
Reboot the drive.
Ensure the operating system initializes the disc before opening MakeMKV.
Ensure you have allowed MakeMKV internet access in preferences as it's needed to download the UHD hashed keys.
BALWC6
#2777 Post by BALWC6 » Fri Feb 28, 2025 10:29 pm
Looking to get a Blu-Ray writer that can do 4K, I currently have a Samsung SE-506CB/RSBD and I wasn't sure if it is 4K capable. The drives I'm looking at are below:
LG Electronics BP60NB10: https://a.co/d/dKhFKgh
Pioneer BDR-XD08UMB-S: https://a.co/d/iDUI0VH
I've done the reading on the Pioneer drives don't work, but I do prefer them in terms of looks and quality. Any advice is appreciated!
mm13579
#2778 Post by mm13579 » Fri Feb 28, 2025 10:42 pm
Restarted everything and waited like you said and I have always had Internet access turned on for makemkv and it gets further now but says there is an error then about 300 files where skipped due to the length not being at least 400 seconds and then said failed to open disc at the end. I had to reboot my PC for it to display the disc drive as well as it was no longer an option
BALWC6
#2779 Post by BALWC6 » Sat Mar 01, 2025 3:11 am
BALWC6 wrote: Fri Feb 28, 2025 10:29 pm Looking to get a Blu-Ray writer that can do 4K, I currently have a Samsung SE-506CB/RSBD and I wasn't sure if it is 4K capable. The drives I'm looking at are below:
Turns out my Plex Media Server tower has a drive already in there. I have an LG WH16NS40 drive. So going to attempt the flashing of the firmware from the guide.
#2780 Post by MartyMcNuts » Sat Mar 01, 2025 3:17 am
BALWC6 wrote: Sat Mar 01, 2025 3:11 am
Just make sure the WH16NS40 is manufactured after October 2015, has the SVC NS50 code on the sticker and has the MT1959 drive platform BEFORE ATTEMPTING TO FLASH IT!!
BALWC6
#2781 Post by BALWC6 » Sat Mar 01, 2025 3:29 am
MartyMcNuts wrote: Sat Mar 01, 2025 3:17 am
4K Rip.png (90.43 KiB) Viewed 13080 times
It worked the drive was manufactured in 2017 and I did the GUI based tool and the Google Drive link for the firmware packs. In the screenshot you can see I'm doing a rip of the 4K version of Macross Do You Remember Love I just got in today. I'm happy that Iucked out with already having the drive. Looking forward to being able to rip Ultra HD Blu Rays!!!
mm13579
#2782 Post by mm13579 » Sat Mar 01, 2025 7:29 pm
Since it said failed to open disc and said no drive available I can no longer get it to load UHD discs only Blu Ray and DVDs if I put in a UHD Disc it says no discs after it attempts to load?
Also it's still running 1.03 MK Firmware and it's the BU40N
Any ideas or is the drive broken for UHD
kbhales
#2783 Post by kbhales » Sun Mar 02, 2025 3:03 am
How exactly do I modify the OWC Mercury Pro enclosure?
#2784 Post by Coopervid » Sun Mar 02, 2025 12:47 pm
kbhales wrote: Sun Mar 02, 2025 3:03 am How exactly do I modify the OWC Mercury Pro enclosure?
Just bend the attachment tabs a litte. See this picture:
https://mega.nz/file/mV5mCDhT#T794dO696 ... l_wcIH352A
kbhales
#2785 Post by kbhales » Sun Mar 02, 2025 1:56 pm
Coopervid wrote: Sun Mar 02, 2025 12:47 pm
What tools would you recommend I use to do this?
#2786 Post by Billycar11 » Sun Mar 02, 2025 2:50 pm
kbhales wrote: Sun Mar 02, 2025 1:56 pm
You can also slot it with a Dremel
shinkiro
#2787 Post by shinkiro » Sun Mar 02, 2025 3:04 pm
zittrig wrote: Thu Feb 20, 2025 9:22 pm Try flashing with LG BU40N 1.03MK.
Thank you once again, I managed to flash my Buffalo drive successfully with LG BU40N 1.03MK
Do I need to flash it further with one of these three firmwares?
DE_Buffalo_BRUHD-PU3_BN12-MK
DE_Buffalo_BRUHD-PU3_BU10
DE_Buffalo_BRUHD-PU3_BU12-MK
#2788 Post by Coopervid » Sun Mar 02, 2025 3:18 pm
Just bend it with a straight nose plier.
#2789 Post by Coopervid » Sun Mar 02, 2025 3:19 pm
shinkiro wrote: Sun Mar 02, 2025 3:04 pm
No.
mm13579
#2790 Post by mm13579 » Mon Mar 03, 2025 10:55 pm
I have makemkv 1.17.9.
I have BU40N running 1.03 mk firmware
I can only run UHD discs up to AACS 68
I have several that are AACS 77 how do I get them to register with my drive if I load anything above 68 it says no disc after it spins up and down.
If I load a 68 or below in about 20-30 seconds it loads right up see photo and I can make a copy with no issues.
What do I need to do from here to get the key database updated to accept AACS 77?
