Pioneer BDR-UD03 UHD possibility
Thejs1234
Re: Pioneer BDR-UD03 UHD possibility
#526 Post by Thejs1234 » Fri Feb 21, 2025 4:21 pm
Hello Coopervid,
I also have a BDR-UD03 with the following info :
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
I would love to be able to read UHD Drives. Thanks in advance
samh2575
#527 Post by samh2575 » Sat Mar 01, 2025 2:58 pm
Hi, I have recently acquired a Verbatim 43889 (Pioneer BD-RW BDR-UD03) and have been able to rip both DVD and BR out of the box.
I would love to start ripping my 4k BRs, but currently, the drive seems unable to read them. I understand from reading through this forum that this drive can be flashed to read UHD disks? I'm not sure where to start with this, but any help would be truly appreciated!
Drive information:
Revision: 1.14
Serial number:
Highest AACS version: 66
Thanks in advance!
qupfer
#528 Post by qupfer » Sat Mar 01, 2025 3:27 pm
i'm also interesetd in flashing information :-) Thanks
AiRLAC
#529 Post by AiRLAC » Sat Mar 01, 2025 5:24 pm
Coopervid wrote:
Sat Feb 15, 2025 6:32 pm
Again. One-time-posters need to come back and show interest.
So I did, what do you exactly need from us?
#530 Post by Coopervid » Sat Mar 01, 2025 8:24 pm
jusinlee wrote:
Wed Feb 19, 2025 7:52 am
Hi Coopervid,
I bought a Verbatim drive (BD-RW BDR-UD03) and a MakeMKV license key.
Here is the drive info:
OS device name: E:
Revision: 1.14
Serial number: DL
Highest AACS version: 81
Would you be able to send me the firmware?
I will come back :)
Thanks.
PM sent.
#531 Post by Coopervid » Sat Mar 01, 2025 8:25 pm
MagnusMelauach wrote:
Wed Feb 19, 2025 4:20 pm
Hi, i have the same drive (BD-RW BDR-UD03; Rev 1.14; Firmware Date 2020-06-15).
Im fairly new to this, but do i understand it correctly that it can read UHD disks? And if yes, could you show me how to get it working?
Thanks in advance :D
PM sent.
#532 Post by Coopervid » Sat Mar 01, 2025 8:28 pm
Hello Coopervid,
Revision: 1.14
Serial number:...
PM sent.
#533 Post by Coopervid » Sat Mar 01, 2025 8:35 pm
Drive information:
Revision: 1.14
Serial number:
Thanks in advance!
PM sent
#534 Post by Coopervid » Sat Mar 01, 2025 8:37 pm
You need to post your Makemkv info.
#535 Post by Coopervid » Sat Mar 01, 2025 8:39 pm
Post your Makemkv information.
Syntax17
#536 Post by Syntax17 » Sun Mar 02, 2025 6:12 pm
Coopervid wrote:
Thu Feb 29, 2024 4:49 pm
PM sent.
Hi, can you also send it to me? I can't send DMs yet :(
#537 Post by dcoke22 » Sun Mar 02, 2025 6:56 pm
PM sent.
Undoubtedly Coopervid will ask you to post your MakeMKV drive info, so you might as well do that now. :)
Alekz
#538 Post by Alekz » Tue Mar 04, 2025 8:53 pm
Hello, is this firmware flashable as well?
Revision: 1.14
Serial number: ...
Kind regards
#539 Post by Billycar11 » Tue Mar 04, 2025 11:59 pm
Revision: 1.14
Serial number: ...
Kind regards
Yes email me for the flasher see below
BifiMike
#540 Post by BifiMike » Wed Mar 05, 2025 2:04 pm
Hallo Coopervid
Bought a Verbatim drive with the following info:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ...
Firmware-Datum: 2020-06-15
Highest AACS version: 35
Is it possible to read/rip UHD like the others posted here? Many thanks in advance
