Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Hello Coopervid,
I also have a BDR-UD03 with the following info :
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
I would love to be able to read UHD Drives. Thanks in advance
Revision: 1.14
Serial number:...
Hi, I have recently acquired a Verbatim 43889 (Pioneer BD-RW BDR-UD03) and have been able to rip both DVD and BR out of the box.
I would love to start ripping my 4k BRs, but currently, the drive seems unable to read them. I understand from reading through this forum that this drive can be flashed to read UHD disks? I'm not sure where to start with this, but any help would be truly appreciated!
Drive information:
Revision: 1.14
Serial number:
Highest AACS version: 66
Thanks in advance!
Drive information:
Revision: 1.14
Serial number:
Thanks in advance!
i'm also interesetd in flashing information
So I did, what do you exactly need from us?Coopervid wrote: Sat Feb 15, 2025 6:32 pm Again. One-time-posters need to come back and show interest.
PM sent.jusinlee wrote: Wed Feb 19, 2025 7:52 am Hi Coopervid,
I bought a Verbatim drive (BD-RW BDR-UD03) and a MakeMKV license key.
Here is the drive info:
OS device name: E:
Revision: 1.14
Serial number: DL
Highest AACS version: 81
Would you be able to send me the firmware?
I will come back
Thanks.
PM sent.MagnusMelauach wrote: Wed Feb 19, 2025 4:20 pm Hi, i have the same drive (BD-RW BDR-UD03; Rev 1.14; Firmware Date 2020-06-15).
Im fairly new to this, but do i understand it correctly that it can read UHD disks? And if yes, could you show me how to get it working?
Thanks in advance![]()
PM sent.Thejs1234 wrote: Fri Feb 21, 2025 4:21 pm Hello Coopervid,
Revision: 1.14
Serial number:...
PM sentsamh2575 wrote: Sat Mar 01, 2025 2:58 pm Hi, I have recently acquired a Verbatim 43889 (Pioneer BD-RW BDR-UD03) and have been able to rip both DVD and BR out of the box.
Drive information:
Revision: 1.14
Serial number:
Thanks in advance!
You need to post your Makemkv info.
Hi, can you also send it to me? I can't send DMs yet
Hello, is this firmware flashable as well?
Revision: 1.14
Serial number: ...
Kind regards
Revision: 1.14
Serial number: ...
Kind regards
Yes email me for the flasher see belowAlekz wrote: Tue Mar 04, 2025 8:53 pm Hello, is this firmware flashable as well?
Revision: 1.14
Serial number: ...
Kind regards
Hallo Coopervid
Bought a Verbatim drive with the following info:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ...
Firmware-Datum: 2020-06-15
Highest AACS version: 35
Is it possible to read/rip UHD like the others posted here? Many thanks in advance
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
