UHD FAQ
Re: UHD FAQ
Thanks for the feedback. I'll take a look and fix that in the next update.
Re: UHD FAQ
That bug should be fixed in the new update I just posted. Thanks again!
Re: UHD FAQ
Thanks SamuriHL, that could be a nice little time saver. Did get windows controlled folder access all mad by trying to write to Documents but but that is expected as it is set to block this sort of thing by default. Had no complaints about pulling down the file and putting the keydb in the MakeMKV folder.
But what isn't good is that it thinks "FindVUK.exe" is a virus and quarantined it Trojan:Win32/Wacatac.B!ml Any thoughts on why it might be triggering it?
Re: UHD FAQ
I got the same thing. It's a false positive. I've been using that version of findvuk since it came out and this is like the third time it's been flagged. My code is pulling it from the findvuk website directly so it's nonsense. Just ignore it.
Sent from my SM-S928U1 using Tapatalk
Re: UHD FAQ
Ok. So when I got the pop-up, I just went ahead and put in my bank account, social security number, mother's maiden name...
I went to the doom9 thread and saw the conversation about it there. Seems to be all good.
(for anyone else wanting to read it: https://forum.doom9.org/showthread.php?t=172472&page=43)
Re: UHD FAQ
Like I said it happens a lot. I just whitelist it each time. I could create a version without findvuk but it does a really good job on differential updates and I'm lazy. Lmao
ictbydesign
Re: UHD FAQ
how do i uninstall this, it does not show anywhere, (KeyDB_Helper).
Thanks.
Thanks.
Re: UHD FAQ
"how do i uninstall this" You delete the files. It never installed so you don't need to uninstall.
ictbydesign
Re: UHD FAQ
Thanks, i did find this out in the end, on one device it put a folder on the desktop and on another it didn't.PaulCB wrote: Fri Feb 28, 2025 6:24 pm "how do i uninstall this" You delete the files. It never installed so you don't need to uninstall.
Re: UHD FAQ
Hi Samury,SamuriHL wrote: Fri Jan 17, 2025 2:43 pm KeyDB Helper (Windows Only)
https://www.mediafire.com/file/7cs6ppux ... .2.7z/file
Thanks a lot for your helper
Will be possibile have a helper that simply do the syncronize without show nothing and then exit?
Kind regards
Re: UHD FAQ
I have no plans to add that no. Sorry.microfast wrote: Sun Mar 30, 2025 4:23 pm
Hi Samury,
Kind regards
Re: UHD FAQ
Those who read my KeyDB Helper post very carefully could be rewarded.
I've updated it to include some new functionality using both FindVUK under the covers and the keydb.cfg file itself once it's downloaded by FindVUK. Enjoy
Re: UHD FAQ
I just released a new version of the KeyDB Helper. I left some debug logging in place in the last release by mistake and it causes the log to grow very quickly. I highly recommend grabbing this release.
Re: UHD FAQ
One more update for the KeyDB Helper. This one locally validates the unit key(s) for your disc and if the locally validated data doesn't match the keydb, it updates the keydb entry for your disc and runs a findvuk validatedisc to update the entry. This allows people to fix bad entries in the keydb.
Re: UHD FAQ
Does it also run findvuk validatedisc for entries with (LEGACY) and/or (NOTVALIDATED) in the comment? Might be useful to run it for those as well.SamuriHL wrote: Fri Apr 25, 2025 12:33 am One more update for the KeyDB Helper. This one locally validates the unit key(s) for your disc and if the locally validated data doesn't match the keydb, it updates the keydb entry for your disc and runs a findvuk validatedisc to update the entry. This allows people to fix bad entries in the keydb.
