Loading BD-Files from HD
mperathoner
I have a couple of ripped BD.Disks and am looking for a way to convert them. Unfortunately makemkv seems not to work: when I try to load the index.bdmv-file, nothing happens. (Message: no disk inserted) Can anybody help??
joe42
Re: Loading BD-Files from HD
Just insert the original bluray disc and use MakeMKV directly.
It should work. Do you get any errors? How did you rip the disc?mperathoner wrote:I have a couple of ripped BD.Disks and am looking for a way to convert them. Unfortunately makemkv seems not to work: when I try to load the index.bdmv-file, nothing happens. (Message: no disk inserted) Can anybody help??
setarip_old
@mperathoner
Hi!
Have you tried to simply PLAY these discs on a stabdalone player or another computer system, or another drive?
Hi!
