BD-RE WH16Ns60
czar99
BD-RE WH16Ns60
#1 Post by czar99 » Fri Feb 28, 2025 7:50 pm
New guy here. I have flashed my drive. But I can't RIP my UHD disk. What am I missing? I have tried 2 different UHD's both clean and brand new.
OS device name: I:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLKNAHF5101
Highest AACS version: 81
Firmware version: 1.02
Re: BD-RE WH16Ns60
#2 Post by MartyMcNuts » Fri Feb 28, 2025 8:50 pm
OS device name: I:
Revision: 1.02
Your drive info looks good. You need to post the content in the log window at the bottom so we can see what errors you are getting.
Also ensure you have allowed MakeMKV internet access in preferences as it is needed to download the UHD hashed keys.
czar99
Re: BD-RE WH16Ns60
#3 Post by czar99 » Fri Feb 28, 2025 9:08 pm
Is it the keydb.cfg?
Re: BD-RE WH16Ns60
#4 Post by MartyMcNuts » Fri Feb 28, 2025 10:44 pm
No. MakeMKV downloads it's own UHD hashed keys that are downloaded and absorbed into your MakeMKV's private_data.tar file.
czar99
Re: BD-RE WH16Ns60
#5 Post by czar99 » Mon Mar 03, 2025 2:02 pm
I think this is what you are looking for.
DEBUG: Code 1 at :<'Da4"<]rw`d`(|kANaF:121262371
DEBUG: Code 12 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 13 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00712.m2ts' is corrupt or invalid at offset 1882656768, attempting to work around
DEBUG: Code 14 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 15 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 16 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 17 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 18 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 19 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 20 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 21 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 22 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 179 at >{`y(>CqW-`Fca0ypbVz:213133250
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131157
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131272
DEBUG: Code 919269 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at hijnaX{Xh8"!jVD5f:tCE:213129984
DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
DEBUG: Code 0 at w7$%Q9>F85'`y2squ:213130996
DEBUG: Code 1 at ^zxXn;o<9_KZZXF@:213132537
Failed to save title 32 to file C:/Users/ce/Videos/ALIEN-FPL_MainFeature_t32.mkv
Encountered 4 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Re: BD-RE WH16Ns60
#6 Post by MartyMcNuts » Mon Mar 03, 2025 11:04 pm
It appears thr drive is having trouble reading the disc. Either:
  • the disc is dirty.
  • the disc is faulty.
  • the drive is faulty.
Always, the first thing to do is clean the disc. Even if it looks pristine, give it a good clean. Just try wiping it with a soft microfibre cloth to start with and see if that helps.
The next step is a more thorough clean using soapy water and a microfibre cloth then pat dry with a microfibre cloth and let sit overnight to fully dry before trying to rip it again.
If it still fails after both steps above and other discs rip ok, it is most likely a faulty disc. If no discs rip at all, it's most likely a faulty drive.
czar99
Re: BD-RE WH16Ns60
#7 Post by czar99 » Tue Mar 04, 2025 4:01 pm
Thanks for the help. DVD's and regular Blu-ray disc work just fine. I tried 2 different UHD, never played before, fresh out of the package and they did not work. I tried a 3rd this morning, same thing UHD, never played before, fresh out of the package BUT I wiped it down with a microfiber cloth first. IT WORKED! I tried one of the others that did not work before but I wiped it with a microfiber cloth and it WORKED. Thanks for the help. Now I will finish the rest of my library.
czar99
Re: BD-RE WH16Ns60
#8 Post by czar99 » Tue Mar 04, 2025 4:59 pm
One of the previous ones did RIP but the second did not. Here is the info. Any thoughts?
Saving 1 titles into directory C:/Users/chris.earnest/Videos
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 1 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 2 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 31934115840, attempting to work around
DEBUG: Code 3 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 4 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 5 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 6 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 7 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 8 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 9 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 10 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 11 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 31934183424, attempting to work around
DEBUG: Code 23 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 24 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 25 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 26 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 27 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 28 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 29 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 30 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 31 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 32 at >{`y(>CqW-`Fca0ypbVz:29394758
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '65304852480'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '65304852480'
DEBUG: Code 3221225628 at e2ZHo%(J'4phL9N]&.:213131502
DEBUG: Code 100864261 at e2ZHo%(J'4phL9N]&.:213131502
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:29395793
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:29394068
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:121262647
DEBUG: Code 31887135 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at ^e;Q-;u]b{c8t&:.HwKk:29394022
DEBUG: Code 0 at ^e;Q-;u]b{c8t&:.HwKk:29404878
DEBUG: Code 0 at ^e;Q-;u]b{c8t&:.HwKk:29405384
DEBUG: Code 0 at ^e;Q-;u]b{c8t&:.HwKk:29403383
DEBUG: Code 0 at )^.~5rs0+e#Je2|y(V@U:213141208
DEBUG: Code 0 at ^zxXn;o<9_KZZXF@:213132537
DEBUG: Code 0 at h+#;3?8hqd\bV%&<Z:29396207
DEBUG: Code 0 at h+#;3?8hqd\bV%&<Z:121264257
DEBUG: Code 0 at h+#;3?8hqd\bV%&<Z:213130490
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 13 to file C:/Users/chris.earnest/Videos/Dune- Part Two_t13.mkv
Encountered 29 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Re: BD-RE WH16Ns60
#9 Post by MartyMcNuts » Tue Mar 04, 2025 10:12 pm
Yes, the drive is having trouble reading the disc. Also, what drive are you writing to? You may want to change the output directory as that storage drive is very slow.
Give the disc a good clean using soapy water and a microfibre cloth. Dry with another cloth then let it air dry overnight before trying to rip it again. If it still doesn't rip, either replace the disc or get another drive. LG's are not as good as they used to be these days. Pioneer drives are far superior.
czar99
Re: BD-RE WH16Ns60
#10 Post by czar99 » Wed Mar 05, 2025 2:04 pm
Thanks for the observation of the target drive (I am not paying attention to those plain as day messages). I am questioning my ripping setup now. It is a desktop so I am going to add a SSD for my MKV's.
fr2gx
Re: BD-RE WH16Ns60
#11 Post by fr2gx » Fri Mar 07, 2025 2:33 am
Thanks! I was having the same issue as OP and allowing internet access fixed it for me.
brmwia
Re: BD-RE WH16Ns60
#12 Post by brmwia » Fri Mar 21, 2025 10:49 pm
I've seen this 2 times on DVD and once on Blu-Ray.
For the Blu-ray I was able to get around it by plugging my external USB-C drive into another port that had more power.
For both DVD's I used DVD Decrypter and it read the disc as error free.
Just saying.. it's not always the disc or the drive.
