LibreDrive firmware for HL-DT-ST BD-RE BU40N
mdhankins1
Post by mdhankins1 »
Hello. I am a little confused about which LibreDrive firmware to pick for this drive. Any help? Using the mk-firmware-pack-20200720.
HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin (BU40N-N-Main)
HL-DT-ST-BD-RE_BU40N-U100-3M01801-211910161036.bin (BU40N-U-Tier2-Non-UHD)
When I view my device in SDFtool Flasher, it shows HL-DT-ST_BD-RE_BU40N_U101_212012011720_MO6L9191353
Re: LibreDrive firmware for HL-DT-ST BD-RE BU40N
The Ultimate UHD Drives Flashing Guide says BU40N on any Firmware directly to > BU40N 1.03MK
mdhankins1
When I try the BU40N 1.03MK firmware I get an error message.
Command produced error code 0xff05c103
(nevermind, I tried the following morning and the flash worked)
Mercutio
Post by Mercutio »
Acutally I am a bit puzzled, too.
I tried to flash my drive, and it looks promising in the first moment:
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d  E: rawflash -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MZFO3UD5238
 100% Operation finished
Done successfully
But after I restarted the pc and open makeMKV it still states this information:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: [Removed]
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Also - I though it might be some drive caching issue - I just gave it a shot. But without luck:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\(...)\(...).tar.gz
Thanks in advance for any help.
EDIT
I also tried the sdftool_flasher with the FW Versions 1.00 and 1.03 (as recommended)
Post by d00zah »
HL-DT-ST-BD-RE_BU40N_1.02_212012011716_MO3L91F0715.bin is listed as an encrypted FW in the guide. Either add enc to the command line, or make sure 'Encrypted FW' (?) is a green check in the GUI tool.
yamslover
Post by yamslover »
OS device name: /dev/sr0
Revision: U100
Serial number: KFNGAJF2958
Firmware date: 2116-08-31 11:53
I am having trouble locating the matching 1.03‑MK for HL-DT-ST_BD-RE_BU40N_U100_211608311153_KFNGAJF2958. Is there any libredrive firmware for this model?
yamslover wrote:
Tue Jan 27, 2026 8:37 pm
Revision: U100
see guide below
or email me or marty for an auto flasher but they are windows only the auto flashers
yamslover
Post by yamslover »
Thank you I was overthinking it and had the enc command in there rather than main, it appears to be working now with the tutorial.
