BW-16D1HT 3.02 MK
Danine
BW-16D1HT 3.02 MK
Someone has a 3.02 MK version for BW-16D1HT, I need specifically this version.
Thank you.
Thank you.
Re: BW-16D1HT 3.02 MK
It's in my firmware pack on the SDFtool flasher thread.Danine wrote: Thu Feb 27, 2025 8:39 pm Hello,
Thank you.
Danine
Hello, I can see only the 3.02 DE but not MK, 3.0.3 MK and 3.10MK in this package:/MartyMcNuts wrote: Thu Feb 27, 2025 10:33 pmIt's in my firmware pack on the SDFtool flasher thread.Danine wrote: Thu Feb 27, 2025 8:39 pm Hello,
Thank you.
I attached a screnshoot.
En your package no appears, only DE (the original), I attach other screenshot.
Maybe you can help me, I bought a Blu-ray from the United States and I am from Spain. The Blu-ray has region A and I have region B.
The Blu-ray is "Straight from the Barrio", theoretically manufactured in 2008.
With firmware 3.10 MK it still doesn't recognize it, and with 3.02, 3.01 and 3.03 MK it still doesn't recognize it.
In all of them it tries to read it but then stops.
Is this a problem with some restriction of the Blu-ray, is it still a region problem or is the disc simply damaged?
The disc is new (not used).
- Files package Marty.png (21.48 KiB) Viewed 11008 times
- MK Files package.png (111.44 KiB) Viewed 11015 times
The region really doesn't matter in your case.
As a first thing wash the disc with warm water and liquid soap. Dry with a paper towel. Wipe with a microfiber cloth as used for cleaning glasses. Try again.
New discs often have an invisible film on them that makes them hard to read.
If it still doesn't work the disc might be defective.
Danine
I did those steps but the same result, not works.Coopervid wrote: Fri Feb 28, 2025 10:41 am The region really doesn't matter in your case.
zittrig
Even the windows recognition doesn't work?
Try it before opening MakeMKV.
Danine
No, not at all.zittrig wrote: Fri Feb 28, 2025 11:51 am Even the windows recognition doesn't work?
There might be a chance to read this disc with a Pioneer drive but it's not guaranteed. You would have to spend at least 100 Euros to get one. These drives perform better compared to LG / ASUS drives.
There is no MK version of 3.02 as the original (DE version) is already UHD compatible and libredrive enabled. MK versions are only created for versions that disabled libredrive and/or UHD readability.Danine wrote: Fri Feb 28, 2025 7:22 amHello, I can see only the 3.02 DE but not MK, 3.0.3 MK and 3.10MK in this package:/MartyMcNuts wrote: Thu Feb 27, 2025 10:33 pmIt's in my firmware pack on the SDFtool flasher thread.Danine wrote: Thu Feb 27, 2025 8:39 pm Hello,
Thank you.
Danine
Yes, I think it would be better to buy a Pioneer. Is there one that can read UHD straight away and not have region problems or any protection like the one I have?Coopervid wrote: Fri Feb 28, 2025 1:35 pm There might be a chance to read this disc with a Pioneer drive but it's not guaranteed. You would have to spend at least 100 Euros to get one. These drives perform better compared to LG / ASUS drives.
Until a few weeks ago I would have recommended the Verbatim slim drive with the UD04. But some now ship with a LG drive. Therefore I recommend the Verbatim with the UD03 which is cheaper but needs to be flashed. Flashing is very easy. Buy it. I will support you.
https://www.amazon.es/VERBATIM-Slimline ... 103&sr=8-5
Danine
Is there a similar one that is internal (SATA) for PC?Coopervid wrote: Fri Feb 28, 2025 8:59 pm Until a few weeks ago I would have recommended the Verbatim slim drive with the UD04. But some now ship with a LG drive. Therefore I recommend the Verbatim with the UD03 which is cheaper but needs to be flashed. Flashing is very easy. Buy it. I will support you.
No. Not anymore. Buy this. It will be doing fine as long as you feed enough power via USB.
Danine
Someone has the verison 3.11 DE (Official) for BW-16D1HT?
No, ASUS never released it to the public.
