This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/...
Saved AACS dump file as /Users/user/Library/MakeMKV/MKB_v44_Riddick_10DE.tgz
I clicked on the given link and this uploaded something to the makemkv site, but I am not sure what to do with this zipped tar-File that got created too.
Shall I upload it somewhere?
How good are the chances that this BD can be ripped later?
I mean the movie is 12 years old!
That's odd. What AACS revision is the disc? What version of MakeMKV are you using?
MartyMcNuts wrote: Thu Feb 27, 2025 11:17 pm
I just tried to continue with Spider-Man with Tobey Maguire and this continues:
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as /Users/user/Library/MakeMKV/MKB_v3_Spider-Man_E82C.tgz
For Spider-Man, the Protection is shown in MakeMKV as: AACS v3
My makeMKV is at v1.17.8, registered!
I will disconnect the drive and reconnect it, also restart make MKV and then check the AACS version of Riddick!
