[SOLVED] New version of AACS protection (multiple Bluray)
ripthem
Post by ripthem »
I tried to rip my Bluray of Riddick (2013) and found this to be the first BD that makemkv cannot rip:
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/...
Saved AACS dump file as /Users/user/Library/MakeMKV/MKB_v44_Riddick_10DE.tgz
I clicked on the given link and this uploaded something to the makemkv site, but I am not sure what to do with this zipped tar-File that got created too.
Shall I upload it somewhere?
How good are the chances that this BD can be ripped later?
I mean the movie is 12 years old!
Re: New version of AACS protection (RIDDICK 2013)
ripthem wrote: Thu Feb 27, 2025 11:14 pm I tried to rip my Bluray of Riddick (2013) and found this to be the first BD that makemkv cannot rip:
That's odd. What AACS revision is the disc? What version of MakeMKV are you using?
ripthem
Post by ripthem »
MartyMcNuts wrote: Thu Feb 27, 2025 11:17 pm That's odd. What AACS revision is the disc? What version of MakeMKV are you using?
I just tried to continue with Spider-Man with Tobey Maguire and this continues:
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as /Users/user/Library/MakeMKV/MKB_v3_Spider-Man_E82C.tgz
For Spider-Man, the Protection is shown in MakeMKV as: AACS v3
My makeMKV is at v1.17.8, registered!
I will disconnect the drive and reconnect it, also restart make MKV and then check the AACS version of Riddick!
ripthem
Re: New version of AACS protection (multiple Bluray)
Post by ripthem »
The Riddick (2013) BD shows as AACS v44:
Disc Information
Label: RIDDICK
Timestamp: 2013-12-10 13:54:37
Protection: AACS v44
Data capacity: 45.53 Gb
Disc type: BD-ROM
Number of layers: 2
And after reconnecting the device and restart of makeMKV, the disk can now be opened!
So no problem anymore, it seems.
Sorry for the disturbance - something was hanging it seems.
