BW-16D1HT 3.02 MK
Danine
BW-16D1HT 3.02 MK
#1 Post by Danine » Thu Feb 27, 2025 8:39 pm
Someone has a 3.02 MK version for BW-16D1HT, I need specifically this version.
Thank you.
Re: BW-16D1HT 3.02 MK
#2 Post by MartyMcNuts » Thu Feb 27, 2025 10:33 pm
Danine wrote: Thu Feb 27, 2025 8:39 pm Hello,
Thank you.
It's in my firmware pack on the SDFtool flasher thread.
Danine
#3 Post by Danine » Fri Feb 28, 2025 7:22 am
MartyMcNuts wrote: Thu Feb 27, 2025 10:33 pm
Thank you.
Hello, I can see only the 3.02 DE but not MK, 3.0.3 MK and 3.10MK in this package:/
I attached a screnshoot.
En your package no appears, only DE (the original), I attach other screenshot.
Maybe you can help me, I bought a Blu-ray from the United States and I am from Spain. The Blu-ray has region A and I have region B.
The Blu-ray is "Straight from the Barrio", theoretically manufactured in 2008.
With firmware 3.10 MK it still doesn't recognize it, and with 3.02, 3.01 and 3.03 MK it still doesn't recognize it.
In all of them it tries to read it but then stops.
Is this a problem with some restriction of the Blu-ray, is it still a region problem or is the disc simply damaged?
The disc is new (not used).
Files package Marty.png (21.48 KiB) Viewed 10809 times
MK Files package.png (111.44 KiB) Viewed 10816 times
#4 Post by Coopervid » Fri Feb 28, 2025 10:41 am
The region really doesn't matter in your case.
As a first thing wash the disc with warm water and liquid soap. Dry with a paper towel. Wipe with a microfiber cloth as used for cleaning glasses. Try again.
New discs often have an invisible film on them that makes them hard to read.
If it still doesn't work the disc might be defective.
Danine
#5 Post by Danine » Fri Feb 28, 2025 11:07 am
Coopervid wrote: Fri Feb 28, 2025 10:41 am The region really doesn't matter in your case.
I did those steps but the same result, not works.
zittrig
#6 Post by zittrig » Fri Feb 28, 2025 11:51 am
Even the windows recognition doesn't work?
Try it before opening MakeMKV.
Danine
#7 Post by Danine » Fri Feb 28, 2025 12:07 pm
zittrig wrote: Fri Feb 28, 2025 11:51 am Even the windows recognition doesn't work?
No, not at all.
#8 Post by Coopervid » Fri Feb 28, 2025 1:35 pm
There might be a chance to read this disc with a Pioneer drive but it's not guaranteed. You would have to spend at least 100 Euros to get one. These drives perform better compared to LG / ASUS drives.
#9 Post by MartyMcNuts » Fri Feb 28, 2025 8:45 pm
Danine wrote: Fri Feb 28, 2025 7:22 am
Thank you.
There is no MK version of 3.02 as the original (DE version) is already UHD compatible and libredrive enabled. MK versions are only created for versions that disabled libredrive and/or UHD readability.
Danine
#10 Post by Danine » Fri Feb 28, 2025 8:51 pm
Coopervid wrote: Fri Feb 28, 2025 1:35 pm There might be a chance to read this disc with a Pioneer drive but it's not guaranteed. You would have to spend at least 100 Euros to get one. These drives perform better compared to LG / ASUS drives.
Yes, I think it would be better to buy a Pioneer. Is there one that can read UHD straight away and not have region problems or any protection like the one I have?
#11 Post by Coopervid » Fri Feb 28, 2025 8:59 pm
Until a few weeks ago I would have recommended the Verbatim slim drive with the UD04. But some now ship with a LG drive. Therefore I recommend the Verbatim with the UD03 which is cheaper but needs to be flashed. Flashing is very easy. Buy it. I will support you.
https://www.amazon.es/VERBATIM-Slimline ... 103&sr=8-5
Danine
#12 Post by Danine » Fri Feb 28, 2025 9:34 pm
Coopervid wrote: Fri Feb 28, 2025 8:59 pm Until a few weeks ago I would have recommended the Verbatim slim drive with the UD04. But some now ship with a LG drive. Therefore I recommend the Verbatim with the UD03 which is cheaper but needs to be flashed. Flashing is very easy. Buy it. I will support you.
Is there a similar one that is internal (SATA) for PC?
#13 Post by Coopervid » Fri Feb 28, 2025 9:45 pm
No. Not anymore. Buy this. It will be doing fine as long as you feed enough power via USB.
Danine
#14 Post by Danine » Sat Mar 01, 2025 6:24 am
Someone has the verison 3.11 DE (Official) for BW-16D1HT?
#15 Post by MartyMcNuts » Sat Mar 01, 2025 6:30 am
Danine wrote: Sat Mar 01, 2025 6:24 am Someone has the verison 3.11 DE (Official) for BW-16D1HT?
No, ASUS never released it to the public.
