ASUS BW-12B1ST
talem84
ASUS BW-12B1ST
#1 Post by talem84 » Wed Mar 13, 2024 7:49 pm
i have an ASUS BW-12B1ST and wanted to know if i could get this uHD friendly? i saw several people do it but wasnt 100% sure.
Re: ASUS BW-12B1ST
#2 Post by Coopervid » Wed Mar 13, 2024 9:36 pm
Post your Makemkv info.
Cy-Fi
Re: ASUS BW-12B1ST
#3 Post by Cy-Fi » Tue Feb 25, 2025 11:50 pm
Coopervid wrote: Wed Mar 13, 2024 9:36 pm Post your Makemkv info.
I'm not the OP but I have the same drive (almost) and same question so I'll just piggy back onto this thread. :D
OS device name:
Manufacturer: ASUS
Product: BC-12B1ST
Revision: 1.02
Firmware date:
Bus encryption flags: 12
Highest AACS version: 81
zittrig
Re: ASUS BW-12B1ST
#4 Post by zittrig » Wed Feb 26, 2025 4:19 am
Please show the LibreDrive information also which should follow after the drive information.
Cy-Fi
Re: ASUS BW-12B1ST
#5 Post by Cy-Fi » Thu Feb 27, 2025 1:16 am
zittrig wrote: Wed Feb 26, 2025 4:19 am Please show the LibreDrive information also which should follow after the drive information.
There is no LibreDrive section on mine. I'm assuming that means I'm SOL, right?
Re: ASUS BW-12B1ST
#6 Post by MartyMcNuts » Thu Feb 27, 2025 2:19 am
Cy-Fi wrote: Thu Feb 27, 2025 1:16 am
Try insereting a blu-ray disc and let MakeMKV initialize it. See if it shows up after that.
Cy-Fi
Re: ASUS BW-12B1ST
#7 Post by Cy-Fi » Thu Feb 27, 2025 4:02 am
MartyMcNuts wrote: Thu Feb 27, 2025 2:19 am Try insereting a blu-ray disc and let MakeMKV initialize it. See if it shows up after that.
Still no LibreDrive section:
OS device name:
Manufacturer: ASUS
Product: BC-12B1ST
Revision: 1.02
Serial number:
Firmware date:
Disc Information
Label: SAVING_PRIVATE_RYAN_1
Timestamp: 2010-05-05 14:02:19
Protection: AACS v17
Data capacity: 43.90 Gb
Disc type: BD-ROM
Number of layers: 2
zittrig
Re: ASUS BW-12B1ST
#8 Post by zittrig » Thu Feb 27, 2025 4:29 am
If not which production date is on the drive's sticker?
Or which front has the drive? Two or three symbols on the right? It doesn't have to be, but it can be a clue.
Cy-Fi
Re: ASUS BW-12B1ST
#9 Post by Cy-Fi » Fri Feb 28, 2025 1:20 am
zittrig wrote: Thu Feb 27, 2025 4:29 am If not which production date is on the drive's sticker?
Manufacture date is June 2012.
I'm not sure what two or three symbols you're referring to. Is it the -20 at the end of the model number?
BC-12B1ST-20
Re: ASUS BW-12B1ST
#10 Post by dcoke22 » Fri Feb 28, 2025 4:41 am
2012 is before UHD existed in the market. The end of 2015 is sorta where things start for UHD. Your drive is undoubtedly too old to support UHD.
But, your drive is still useful for DVDs and regular blu-rays.
zittrig
Re: ASUS BW-12B1ST
#11 Post by zittrig » Fri Feb 28, 2025 6:14 am
With reference to the symbols see below. Usually, with some exceptions, you can identify the new technical platform MT-1959, which is the flashable one, with a look to the front of the ASUS drives.
2 symbols on the right: E-Green and MDisc: MT-1959
3 symbols on the right: RW, DVD Multi, Compact disc: MT-1939
Usually!!! I've had one time a MT-1959 drive (in this case a BC-12D2HT) with the "old" front from late 2015. But yours is to old, bad luck, sorry.
Cy-Fi
Re: ASUS BW-12B1ST
#12 Post by Cy-Fi » Sat Mar 01, 2025 12:15 am
zittrig wrote: Fri Feb 28, 2025 6:14 am With reference to the symbols see below. Usually, with some exceptions, you can identify the new technical platform MT-1959, which is the flashable one, with a look to the front of the ASUS drives.
dcoke22 wrote: Fri Feb 28, 2025 4:41 am 2012 is before UHD existed in the market. The end of 2015 is sorta where things start for UHD. Your drive is undoubtedly too old to support UHD.
That's what I thought but wanted someone more knowledgeable to verify.
Thank you!
