LibreDrive for Pioneer drives
Roothog
Post by Roothog »
Coopervid wrote: Wed Feb 26, 2025 11:01 pm Try to get a Vinpower 212V.
No joy in North America. I will keep looking.
en6ads
Post by en6ads »
Roothog wrote: Wed Feb 26, 2025 11:31 pm
? https://www.amazon.com/gp/aw/d/B08R89FN61
I purchased this last week. It's still available. Edit: in stock, but 2 weeks shipping.
byrtolet
Post by byrtolet »
I have a Pioneer drive, here is the info from makemkv:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number: CGDL000324WL
Firmware date: 2022-12-12
Firmware version: ID72
But when there is a disc inserted (either dvd, or bluray) the makemkv doesn't finish the drive scan.
The sdftool also hangs.
What might be the problem and how to fix it?
Is it possible to enable the LibreDrive functionality (and how)?
byrtolet wrote: Thu Feb 27, 2025 8:20 am I have a Pioneer drive, here is the info from makemkv:
Revision: 1.04
That drive can't be flashed as it has the dreaded post Nov 2022 firmware. It should still work for DVD/BD just not UHD and can't have libredrive enabled. If you want to rip UHD discs, return it.
MidwestPancakes
Post by MidwestPancakes »
Greetings,
I do not own any UHD discs, but I would like to make my drives LibreDrive compatible. I just purchased three new bluray drives, I took the shotgun approach in hopes one might be possible.
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: DDDL001758UC
Firmware date: 2022-12-27
Drive platform: Pioneer RS9330
Firmware version: GENE
OS device name: /dev/sr1
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: SIM2121BG1826
Firmware date: 2121-07-08 16:09
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOEOAMA4115
And, if you might, what is your opinion of these three? My intention was to only keep one or two and return the others. Which would you keep?
otherted
Post by otherted »
I have had this drive for a while and I thought it was not capable of UHD the last time I looked into it, or maybe I just never found the right information. Should it be possible to read UHD now? I see a few other posts for similar drives, so appreciate any advice. It does seem to still have older firmware.
OS device name: E:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8D30
Firmware version: 1.03
MidwestPancakes wrote: Thu Feb 27, 2025 10:38 pm Greetings,
Revision: 1.02
Revision: 1.03
Revision: 1.05
Only the last 2 can have libredrive enabled but I would keep the BU40N and return the WP50NB40. The Pioneer is still a good drive but the firmware is too new and can't be flashed to enable libredrive.
byrtolet
Post by byrtolet »
MartyMcNuts wrote: Thu Feb 27, 2025 9:37 am
Revision: 1.04
The problem is that makemkv doesn't work with DVDs and blurays. It just hangs.
otherted wrote: Thu Feb 27, 2025 11:27 pm I have had this drive for a while and I thought it was not capable of UHD the last time I looked into it, or maybe I just never found the right information. Should it be possible to read UHD now? I see a few other posts for similar drives, so appreciate any advice. It does seem to still have older firmware.
OS device name: E:
Revision: 1.03
Serial number:
PM sent.
dewen
Post by dewen »
I’ve had this BDR-S09J-X drive for a long time and recently registered MakeMKV.
I’d like to make it UHD-compatible. Is this possible?
Any help would be greatly appreciated!
Thank you!"
OS device name: G:
Product: BD-RW BDR-S09JX
Revision: 1.10
Serial number: OADL000272JP
Firmware date: 2014-11-28
Highest AACS version: 81
Drive platform: Pioneer RS8600
toddself
Post by toddself »
Hi @Coopervid,
I see someone else asked you for instructions for this drive, would love instructions on how to flash!
Thank you
OS device name: G:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL0261xxxx
Firmware date: 2022-05-31
Firmware version: ID06
dewen wrote: Mon Mar 03, 2025 11:34 am I’ve had this BDR-S09J-X drive for a long time and recently registered MakeMKV.
Thank you!"
OS device name: G:
Revision: 1.10
PM sent
dewen
Post by dewen »
Coopervid wrote: Mon Mar 03, 2025 4:19 pm
Hi! @Coopervid!
I followed your guide and successfully flashed my BDR-S09J-X to BDR-S11.
Now it’s UHD friendly — thank you so much!
By the way, can my BDR-S08XLT be flashed to S11 like the S09?
OS device name: H:
Product: BD-RW BDR-S08
Revision: 1.40
Serial number: MDDL001589WL
Firmware date: 2014-03-06
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.40/ID43
Yes. Just do the same what you did with your 209.
dewen
Post by dewen »
Coopervid wrote: Tue Mar 04, 2025 11:37 am Yes. Just do the same what you did with your 209.
I don't believe but It works ! Now I have 2 "BDR-S11".
Thank you @Coopervid !
