speaking of clipping on bluray players because they alter the RPU, I found a very good example: Dredd 2012 FEL BD is a very bright grade but the RPU MDL is 1000nits so clipping is visible on bluray players.
The ugoos with CPM A13+, and Shield do not clip...
did some samples https://drive.google.com/drive/u/1/fold ... MU3KAisiAm
daffie
Post by daffie »
RESET_9999 wrote:
Mon Feb 24, 2025 11:14 pm
Dredd 2012 is only HDR10, no ? See here https://www.blu-ray.com/movies/Dredd-4K ... ay/176582/
Do you have a link to a FEL BD for this movie? I don't think this was ever released in Dolby Vision on BD.
EDIT : sorry, there are Dolby Vision versions in the German and Italian releases :-)
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
deadchip12
Post by deadchip12 »
@RESET_9999
In your RPU folder, the file named "Pearl.2022.BD_Generated_OSC" is Bluray rpu with cmv 4.0 already transferred? What does OSC mean?
skull88
Post by skull88 »
OSC = Original Scene/Shot Cuts i.e. not generated but retailed sourced, whether WEB-DL or UHD BD.
deadchip12
skull88 wrote:
Wed Feb 26, 2025 3:52 am
So Pearl.2022.BD_Generated_OSC means it's the original rpu from UHD BD? How come it's cmv 4.0?
Generated means Generated in resolve. Only the scene cuts are original
deadchip12
RESET_9999 wrote:
Wed Feb 26, 2025 11:59 am
So it's ready to be injected into the original bluray mkv file?
Yes, but the original MEL RPU is probably fine. I don't know why there's a generated RPU for that movie on my GD.
EDIT: Ok I generated new metadata because the bd is cmv2.9 without an active/dynamic trim
deadchip12
RESET_9999 wrote:
Wed Feb 26, 2025 3:45 pm
Just curious: if we make mistakes during the cmv 4.0/DV transfer process e.g. the frames are not perfectly synced, will we be able to notice sth wrong in the picture while watching?
yes, brightness adjustements will be visible.
with tthe latest dovi_scripts, you can't do wrong. It will compare both sources scene cuts and tell you if there are differences.
Scene_Cuts_Difference.txt
coopzr
Post by coopzr »
Hi Reset
In the case of a cmv4.0 RPU, if L8 trims are present, do the L2 compatibility trims (100, 600, 1000) get ignored by the tv (assuming tv is cmv4 worthy)?
yes, L2 is always ignored with a cmv4.0 RPU + hardware, even without L8.
deadchip12
@RESET_9999
I just checked Killers of the Flower Moon with dovi scripts and it is the first uhd bluray I see that has cmv 4.0 dolby vision
Gatorman
Post by Gatorman »
I believe Paddington in Peru also has CMv4.0.
More reasons to collect physical media. Ugoos AM6B+.
There are many bluray with cmv4.0. Search ''L8.PLOT'' on my HDR plot Google Drive link.
found all of these in just a 2 min search
deep blue sea
antiviral
ghost of mars
virtuosity
12 monkeys
wolf wall street
the substance
kill
congo
in a violent nature
RoboCop
the keep
