Charlie Countryman Errors
ShevyMate
Post by ShevyMate »
Hi there, i'm trying to rip The Death of Charlie Countryman but i keep getting errors and then the only file left is a 4GB file.
I am getting debug codes and then when trying to make the mkv it says it encountered 72 errors of type 'read error"
I have attached my log for anyone to checkout.
MakeMKV_log.txt
(26.02 KiB) Downloaded 241 times
Re: Charlie Countryman Errors
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
Errors like that indicate that the optical drive is unable to correctly read the disc. The general advice is to gently clean the disc and try again.
003025:0000 Title #00003.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Those 5 titles were skipped because they're too short.
003307:0000 File 00004.m2ts was added as title #0
This is presumably the 4GB file that remains.
ShevyMate
Post by ShevyMate »
I did try to clean the disk and it seems in better condition than the other bunch i did.
I'm going to do a full rip this time and see what happens at the end, as i ended up closing it and going to bed XD
ShevyMate
Post by ShevyMate »
here's my full log
MakeMKV_log.txt
(26.02 KiB) Downloaded 231 times
