Gods of Egypt - about 100 titles showing
Re: Gods of Egypt - about 100 titles showing
Must use powerdvd 14 + versions that is purchased. Screen pass checks 3 things.
1. Disk structure
2. Watermark imbedded in platter
3. Licence Blu-ray player
If any of these required checks are not met the screen pass kicks in.
This is why other Blu-ray software players from other companies do not work or ISO copies of the original. Nice to see I've helped many with the videos I uploaded awhile back.....
1. Disk structure
Netflix rental USA with Process Monitor and PowerDVD 15 give me 419 mpls.
P.S. And it was the wrong title, so Procmon and PowerDVD 15 are not 100% accurate.
I have Gods of Egypt with UPC 03139824564 and I need some help with the mpls
foamie wrote:I think the redbox version is 519,502,508,520,510,506,509,512,504,513,517,501,514,516,511,518,515,505,507,503. I pieced together the movie after watching it and then playing each m2ts file in order that I remember from the movie.
898.mpls matches this mapping.
I'm with you on this one. I got from Netflix and all the listings start with 519. I'm doing this one and will see what happens.
FatLibertarianDude
On mine 00320.mpls is the correct one. Segment map: 510, 519, 512, 515, 516, 509, 504, 511, 505, 502, 518, 514, 507, 503, 501
Best Buy online purchase.
I will verify after decryption. It's safe to assume this is the correct one unless I come back and edit. I will know in about an hour.
You are awesome thank you for this! Not many people post the Netflix ones!spiceygas wrote:Confirmed that track 898 is correct for the Netflix disc.
I purchased my copy from FamilyVideos.com and 898 is the correct one, my UPC code is: 3139824482
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
Can you set .m2ts filter and press play and fast forward movie. Will it spit out the segment map? If you find that mpls is easy to find with bdedit. I dont have pdvd15. Thats why im asking.elviejo wrote:Netflix rental USA with Process Monitor and PowerDVD 15 give me 419 mpls.
Mercilesswaysdesigns
I have the same UPC but no 898.mplskfreeb wrote: Sun Oct 23, 2016 8:22 pm I purchased my copy from FamilyVideos.com and 898 is the correct one, my UPC code is: 3139824482
mediamonkey
Hope this helps someone
UPC: 3139824565
Name: Gods of Egypt (3D+Bluray+DVD+Digital edition)
Source file name: 00320.mpls
Segment map: 510,519,512,515,516,509,504,511,505,502,518,514,507,503,501
File name: GodsofEgypt.mkv
UPC: 3139824565
I also have the Blu-ray 3D combo pack with the same 3139824565 UPC.
On the 3D disc in my set, there is no 000320.mpls playlist.
Using VLC and Process Manager I was able to identify 00434.mpls as the correct playlist for the 3D disc feature.
jbartlett777
UPC 031398244813 played 00510 (not the same as previously reported on page 1) for me using Process Monitor to identify, same one MakeMKV identified.
Segment map: 510,519,512,515,516,509,504,511,505,502,518,514,507,517,503,501
Duration: 2:07:33
Duration: 2:07:33
