Post by RESET_9999 » Mon Feb 24, 2025 1:11 pm
No, it won't clip. Why do you think it would?
L1 and MDL are ok, L2 100nits will get extrapolated to your TV target
Will it clip on a 600-900 nit device?
Post by RESET_9999 » Mon Feb 24, 2025 11:14 pm
speaking of clipping on bluray players because they alter the RPU, I found a very good example: Dredd 2012 FEL BD is a very bright grade but the RPU MDL is 1000nits so clipping is visible on bluray players.
The ugoos with CPM A13+, and Shield do not clip...
did some samples https://drive.google.com/drive/u/1/fold ... MU3KAisiAm
daffie
Post by daffie » Tue Feb 25, 2025 9:22 am
Dredd 2012 is only HDR10, no ? See here https://www.blu-ray.com/movies/Dredd-4K ... ay/176582/
Do you have a link to a FEL BD for this movie? I don't think this was ever released in Dolby Vision on BD.
EDIT : sorry, there are Dolby Vision versions in the German and Italian releases :-)
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
deadchip12
Post by deadchip12 » Wed Feb 26, 2025 2:38 am
@RESET_9999
In your RPU folder, the file named "Pearl.2022.BD_Generated_OSC" is Bluray rpu with cmv 4.0 already transferred? What does OSC mean?
skull88
Post by skull88 » Wed Feb 26, 2025 3:52 am
OSC = Original Scene/Shot Cuts i.e. not generated but retailed sourced, whether WEB-DL or UHD BD.
deadchip12
Post by deadchip12 » Wed Feb 26, 2025 5:17 am
So Pearl.2022.BD_Generated_OSC means it's the original rpu from UHD BD? How come it's cmv 4.0?
Post by RESET_9999 » Wed Feb 26, 2025 11:59 am
Generated means Generated in resolve. Only the scene cuts are original
deadchip12
Post by deadchip12 » Wed Feb 26, 2025 3:43 pm
So it's ready to be injected into the original bluray mkv file?
Post by RESET_9999 » Wed Feb 26, 2025 3:45 pm
Yes, but the original MEL RPU is probably fine. I don't know why there's a generated RPU for that movie on my GD.
EDIT: Ok I generated new metadata because the bd is cmv2.9 without an active/dynamic trim
deadchip12
Post by deadchip12 » Thu Feb 27, 2025 4:12 pm
Just curious: if we make mistakes during the cmv 4.0/DV transfer process e.g. the frames are not perfectly synced, will we be able to notice sth wrong in the picture while watching?
Post by RESET_9999 » Thu Feb 27, 2025 4:27 pm
yes, brightness adjustements will be visible.
with tthe latest dovi_scripts, you can't do wrong. It will compare both sources scene cuts and tell you if there are differences.
Scene_Cuts_Difference.txt
coopzr
Post by coopzr » Fri Feb 28, 2025 10:08 pm
Hi Reset
In the case of a cmv4.0 RPU, if L8 trims are present, do the L2 compatibility trims (100, 600, 1000) get ignored by the tv (assuming tv is cmv4 worthy)?
Post by RESET_9999 » Fri Feb 28, 2025 10:40 pm
yes, L2 is always ignored with a cmv4.0 RPU + hardware, even without L8.
deadchip12
Post by deadchip12 » Sat Mar 01, 2025 1:35 am
@RESET_9999
I just checked Killers of the Flower Moon with dovi scripts and it is the first uhd bluray I see that has cmv 4.0 dolby vision
Gatorman
Post by Gatorman » Sat Mar 01, 2025 2:53 am
I believe Paddington in Peru also has CMv4.0.
More reasons to collect physical media. Ugoos AM6B+.
