louisefindlay23
Post
by louisefindlay23 » Sun Feb 23, 2025 6:03 pm
Hi.
First time ripping BDs today with the new drive I received for my birthday and curious if it's 4K capable. I would appreciate if someone can let me know if it's flashable and I can consider buying some 4K discs in the future.
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 25
Drive platform: RS8591
Firmware version: 1.10/ID22
Post
by Coopervid » Sun Feb 23, 2025 9:35 pm
louisefindlay23 wrote: Sun Feb 23, 2025 6:03 pm
Hi.
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
louisefindlay23
Post
by louisefindlay23 » Sun Feb 23, 2025 11:17 pm
Coopervid wrote: Sun Feb 23, 2025 9:35 pm]
PM sent.
Thanks so much, Coopervid. I couldn't figure out how to reply to your PM so I hope you receive my thank you message.
Skorm
Post
by Skorm » Mon Feb 24, 2025 12:21 am
Good evening,
i was wondering if this drive can be flashed for 4K discs?
Best regards, Skorm
- Bildschirmfoto 2025-02-24 um 01.16.23.png (157.64 KiB) Viewed 24703 times
Post
by Billycar11 » Mon Feb 24, 2025 3:01 am
Skorm wrote: Mon Feb 24, 2025 12:21 am
Good evening,
Best regards, Skorm
yes but only on windows see email below
kbhales
Post
by kbhales » Tue Feb 25, 2025 3:31 am
So I've been a lurker on here and the subreddit for a while and I finally need to post a question. Recently my LG drive has been making weird noises every time I turn it on and I fear that it's on it's last leg. So I ordered two of the Pioneer BDR-212Vs from the Amazon listing that's been blowing up (fingers crossed they're pre-December 2022). I am aware that I need to email Billy for the flasher but I've also seen people messaging Cooper for it as well. I'm a little confused about what the difference is between messaging Billy or Cooper for the flasher and just needed a little more clarification.
en6ads
Post
by en6ads » Tue Feb 25, 2025 11:25 pm
Hi @Coopervid,
I have a new BDR-212v that I need to flash:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL0261xxxx
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
Would love to get your help,
Many thanks.
Post
by Coopervid » Tue Feb 25, 2025 11:36 pm
kbhales wrote: Tue Feb 25, 2025 3:31 am
Same thing.
Post
by Coopervid » Tue Feb 25, 2025 11:37 pm
en6ads wrote: Tue Feb 25, 2025 11:25 pm
Hi @Coopervid,
OS device name: G:
Revision: 1.02
Many thanks.
PM is coming.
kbhales
Post
by kbhales » Wed Feb 26, 2025 1:10 am
Coopervid wrote: Tue Feb 25, 2025 11:36 pm
Same thing.
Gotcha, thanks for clearing my confusion.
en6ads
Post
by en6ads » Wed Feb 26, 2025 4:05 am
Coopervid wrote: Tue Feb 25, 2025 11:37 pm
Hi @Coopervid,
OS device name: G:
Revision: 1.02
Many thanks.
PM is coming.
Thank you. Simple instructions, easy to flash, took a few seconds.
I can recommend the 212v. Mine was purchased from Amazon for $90 last week and it's brand new, manufactured in March 2024, shipped with May 2022 firmware.
Roothog
Post
by Roothog » Wed Feb 26, 2025 9:50 pm
Ordered a Pioneer BDR-X13U-S from Amazon last week with my fingers crossed. Based on what I am seeing don't do it:
OS device name: H:
Product: BD-RW BDR-X13U
Revision: 1.04
Serial number: DFDLXXXXXXXX
Firmware date: 2023-08-01
Firmware version: ID29
Correct me if I am wrong but the Firmware date is after November of 2022 so it needs to go back.
(Which is a real shame as this is probably the nicest external drive I've ever owned.)
Post
by Coopervid » Wed Feb 26, 2025 10:12 pm
Roothog wrote: Wed Feb 26, 2025 9:50 pm
OS device name: H:
Revision: 1.04
Yes. Can't be flashed.
Roothog
Post
by Roothog » Wed Feb 26, 2025 10:17 pm
Coopervid wrote: Wed Feb 26, 2025 10:12 pm
Thanks for the quick reply. Return will be processed ASAP.
Now to find one of these that will work.
Post
by Coopervid » Wed Feb 26, 2025 11:01 pm
Roothog wrote: Wed Feb 26, 2025 10:17 pm
Try to get a Vinpower 212V.
