Re: SDFtool Flasher
Post by MartyMcNuts » Fri Feb 21, 2025 10:29 pm
beancounter wrote: Tue Feb 18, 2025 3:12 am Mr McNuts - I thank you very much. My drive is whirring away ripping NxNW as I type. A testament to a community with helpful people. Much appreciated...
You're welcome!!
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Mon Feb 24, 2025 12:29 pm
Hi All, I'm hoping for some help. I just had a new Vebatim Drive Delivered 43888. I tried to flash it today but I get the error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." I'm trying to install the firmware DE_LG_BU40N_1.03_MK.bin
These are the drive details;
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOAOB1F5013
Any help or guidance would be massively apprecitated. I'm hoping to back up my 4k discs. Cheers.
zittrig
Re: SDFtool Flasher
Post by zittrig » Mon Feb 24, 2025 4:16 pm
Did you have checked "enc"?
Re: SDFtool Flasher
Post by Coopervid » Mon Feb 24, 2025 5:41 pm
shieldsup wrote: Mon Feb 24, 2025 12:29 pm Hi All, I'm hoping for some help. I just had a new Vebatim Drive Delivered 43888. I tried to flash it today but I get the error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." I'm trying to install the firmware DE_LG_BU40N_1.03_MK.bin
Revision: 1.05
This is weird. The drive platform information is missing in your Makemkv info which suggests that this drive is based on a nwe chipset instead of MT1959. Then it can't be flashed. I suggest to return it. What's your country of residence?
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Mon Feb 24, 2025 10:46 pm
I'm in Australia. Bought it through Amazon.com.au
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Mon Feb 24, 2025 10:48 pm
I opened up Makemkv on my Mac and this is what it tells me;
OS device name: /dev/rdisk2
Revision: 1.05
Serial number: *******
Highest AACS version: 77
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Tue Feb 25, 2025 10:02 pm
Coopervid wrote: Mon Feb 24, 2025 5:41 pm
Revision: 1.05
I bought the drive in Australia from Amazon.com.au
Revision: 1.05
Re: SDFtool Flasher
Post by Coopervid » Tue Feb 25, 2025 10:09 pm
Just follow the guide.
viewtopic.php?f=16&t=19634
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Tue Feb 25, 2025 11:42 pm
Coopervid wrote: Tue Feb 25, 2025 10:09 pm Just follow the guide.
That's the problem I thought I had there are a lot of different scenarios but I got that error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." So am I missing a step or did I not do something right?
Re: SDFtool Flasher
Post by Coopervid » Tue Feb 25, 2025 11:44 pm
shieldsup wrote: Tue Feb 25, 2025 11:42 pm
Post your command line. There's also an override but I'm not good with Mac computers.
shieldsup
Re: SDFtool Flasher
Post by shieldsup » Wed Feb 26, 2025 12:13 am
Coopervid wrote: Tue Feb 25, 2025 11:44 pm
Sorry I did this using the SDFtool Flasher Windows GUI Tool not on the mac. I use Parrallels which allows me to have a Windows machine on my Mac as well. Does it have something to do with the 1.05 version of the drive and the Flash Firmware is 1.03?
onkloud9
Re: SDFtool Flasher
Post by onkloud9 » Thu Feb 27, 2025 12:24 am
Thanks Marty McNuts, it worked!
I got an error during the second flash but my BP50NB40 works perfectly.
Re: SDFtool Flasher
Post by dcoke22 » Thu Feb 27, 2025 1:41 am
shieldsup wrote: Wed Feb 26, 2025 12:13 am Sorry I did this using the SDFtool Flasher Windows GUI Tool not on the mac. I use Parrallels which allows me to have a Windows machine on my Mac as well. Does it have something to do with the 1.05 version of the drive and the Flash Firmware is 1.03?
I'd be surprised if flashing firmware worked via Parallels.
swkeith
Re: SDFtool Flasher
Post by swkeith » Sat Mar 01, 2025 10:43 pm
Just followed the guide and used the software to flash my WP50NB40 to the BU40N. Holy cow that was easy, can't believe I waited so long to try it. Currently in the middle of ripping my first UHD and then will try and rip a regular BD to confirm that still works. Thanks so much for all the work on this!
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Mar 02, 2025 1:13 am
swkeith wrote: Sat Mar 01, 2025 10:43 pm Just followed the guide and used the software to flash my WP50NB40 to the BU40N. Holy cow that was easy, can't believe I waited so long to try it. Currently in the middle of ripping my first UHD and then will try and rip a regular BD to confirm that still works. Thanks so much for all the work on this!
You're welcome! Enjoy!!
