Read errors while ripping Mr. & Mrs. Smith
ptr727
Post by ptr727 »
I am trying to rip Mr. & Mrs. Smith BD:
http://www.amazon.com/gp/product/B000MGB6M8
The rip completes about 70%.
Then the NT eventlog starts reporting: The device, \Device\CdRom0, has a bad block.
If I rip from a SATA drive, MakeMKV reports a read failure, and aborts the rip.
If I rip from a USB drive, MakeMKV UI stops responding, and I have to powerdown the USB drive before MakeMKV starts responding again.
I tried to rip the disc using a different ripping product, it also reported a read error.
The disc plays fine on a BD player.
Here is a debug log snippet while ripping from a SATA drive:
005014:0000 Saving 1 titles into directory D:/Rip/BD/MKV/Mr. & Mrs. Smith (2005)
001003:0020 DEBUG: Code 3221225628 at .-TB~Ym>|qhnh://b,=HR0:)D:29394459
001003:0020 DEBUG: Code 3221225628 at THY*ge,V1q ;.6zf:29393723
001003:0020 DEBUG: Code 2 at N\uM)>?/JuAP@VIL:213136562
002003:0000 Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '24873271296'
001003:0020 DEBUG: Code 0 at ;_}V]r3A/Un?(BN)CVo0:29394298
001003:0020 DEBUG: Code 0 at 5$ent%&R\Wr^2Mzw3;vJ:121261681
001003:0020 DEBUG: Code 0 at ;_}V]r3A/Un?(BN)CVo0:29394183
001003:0020 DEBUG: Code 12145152 at ;_}V]r3A/Un?(BN)CVo0:29393309
005003:0000 Failed to save title 0 to file D:/Rip/BD/MKV/Mr. & Mrs. Smith (2005)/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Feb 10 20:22:29 2011
Any ideas?
P.
setarip_old
Re: Read errors while ripping Mr. & Mrs. Smith
Post by setarip_old »
Unless all of your drives are failing, which I doubt, I'd speculate that your disc is either physically damaged or dirty. Try cleaning the disc.
Did you purchase a new disc or a used disc from Amazon?
ptr727
Post by ptr727 »
The disc appears physically clean and scratch-free.
Purchased new from Amazon.
Plays fine on my Panasonic BP player.
Fails to read on two different BD drives in my PC, both Plextor drives.
Will try with a different brand BD drives.
P.
rodimushh
Post by rodimushh »
I am unable to get this one either with a brand-new disc out of the production case from BB. No scratches or problems with the disc. It will play in any machine but I get the following error at the very end of the rip (very frustrating!!!):
Saving 12 titles into directory M:/Dump 5
Failed to save title 0 to file M:/Dump 5/title00.mkv
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '24873271296'
Failed to save title 1 to file M:/Dump 5/title01.mkv
It will rip all of the other titles on the disc just not the feature.
Help please!
setarip_old
@rodimushh
Hi!
Try using MakeMKV to first make a FULL DISC backup - and then use that backup as your source for making the .MKV...
